Sky InsuranceJMB Retrofits
Results 1 to 7 of 7
    Dec 2013
    Horrifying steering issue,
    We have a 2001 163 T Sport, Recently I drove the car after my partner complaining of it not driving as it should...
    I did, and WHAT!!!! - It has something seriously up with either the suspension or the steering setup.
    It feels like the front wheels going over uneven surfaces are connected to a Tesco trolley wheel setup, just wanders all over the place - while the steering wheel is tight in my hand!
    I am no mechanic, But would assume track rod, or ball joint play normally, I would normally have a look and feel, But upon getting under the Audi, I can say the suspension setup is waaaaay more complex than I am used to. lots of complicated arms everywhere!
    Any advice before I get toasted at a garage!?
    Thanks...
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,149
    Check the tyre pressures & tracking, sounds like it could be a dud ball joint though.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Lancaster
    1,779
    It does look a little daunting at first. But it's fairly simple. Jack it up, use the wheel as a lever to work out where the play is.
    Only replace parts with Meyle or Lemforder.
    To do: None yet.
    Nov 2010
    13
    in my case, a broken spring
    Dec 2013
    Ok - Problem sorted,
    However what I found was utterly alarming!
    I jacked the passenger side up & the wheel has soooo much play, it was as if my wheel bolts were 95% undone, I looked behind the wheel and the inside of the hub - surrounding the CV joint are some large allan key fitment bolts, One was undone entirely except one turn! Grease has escaped from the hole it is in too,
    Can anyone shed light on what was loose, I am assuming it was what the hub was connected to? I just ensured they were all rock tight, and car is A1 again....
    Why would this come loose?
    S3 GAZ's Avatar
    Dec 2006
    East Ayrshire Scotland
    343
    I have the exact same problem with car wandering all over the place. Just developed over past week.
    Will get it jacked up in the next day or so and have a look and play with the wheel. Hopefully an easy cheap fix like yourself
    Feb 2012
    Liverpool
    1,149
    Those long bolts hold the wheel bearing assembly in place and have threadlock on them from the factory.
    Only thing I can suggest is that the wheel bearing has been replaced at somepoint and the bolts not fully tightened.
    - Weitec GT
  1. steering issue
    By gazza170 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th November 2009, 15:47
  2. corsa 1.2 steering issue
    By rasA4 in forum Other Brands & Models
    Last Post: 5th November 2008, 23:19
  3. Steering issue
    By jibbajabba in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd July 2007, 12:41
  4. Another steering issue...
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th April 2006, 11:42
  5. More steering issues
    By powerplay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th March 2006, 12:48
