JMB RetrofitsVolks Autos
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By Rudedaubin
Thread: Cabriolet window switches, how to change them?
    Oct 2005
    bristol, uk
    757
    All windows work
    But the passenger rear side doesn't always go up if using the switch alone but will go up with the big main controller
    So I assume either a dirty connection or dodgy connection as it sometimes work
    How do you get them out thinking I might try and clean the area or just in case I need to change them?
    Researching and potentially looking for a nice S4 B6
    Previous cars: Modded Toyota Celica 1.8 Vvtli, modded mk1 TT, standard mkv r32 dsg
    Current: family wagon diesel
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    Theres a tiny hole in the door handle under the bank of switches. Stick something in that like a terminal screwdriver and you should be able to release the switches from the car. I stripped mine and drowned them with electrical contact cleaner to get them working again.
    2004 A4 Sport Cabriolet 3.0
    Oct 2005
    bristol, uk
    757
    Drowned in electrical contact cleaner!?
    What is this, link please?
    Literally just dunk it in?
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    Sorry just expressing that I sprayed a hell of a lot of electrical contact cleaner into the switches to clean them, This is the stuff that I used Halfords | Halfords Electrical Contact Cleaner 400ml
    Oct 2005
    bristol, uk
    757
    Brilliant
    So it just pops out and clips back in?
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    Yes, just pushes out from underneath. I went further and stripped the covers off and then sprayed loads of cleaner into the switches. you can't harm them with the contact cleaner so get plenty in there and you should be good as new again.
    p1tse likes this.
    Sep 2013
    Portsmouth
    245
    If you can take it apart enough to get to the brass contacts clean them with some sort of cleaner to remove any dirt (I used some old stinky aftershave) then clean the contacts with a pencil eraser.
    Oct 2005
    bristol, uk
    757
    Quote Originally Posted by Rudedaubin View Post
    I tried to feel for the whole but couldn't
    Is it directly under the bank of switches?
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    It's the underneath of the door handle below the switches. its near the front edge of the switches and is quite small but once you find it you'll wonder how you've not seen it before.
    Oct 2005
    bristol, uk
    757
    This one which is more in front rather than directly underneath?
    If so I need something thin!
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    Yes that's the one. I used a small screwdriver
    p1tse likes this.
    Oct 2005
    bristol, uk
    757
    What's the difference between contact cleaner or electrical cleaner as I have contact cleaner from maplins
    Maplin Contact Cleaner 200ml | Maplin
    Oct 2005
    bristol, uk
    757
    Managed to get the bank of switch out
    Took some going to get the surround away from switches
    Sprayed the contacts with contact cleaner, dried and tested, and all work a dream now
    Only down side the rubber texture of the switches have gone very stick.
    Any recommendations on how to clean sticky surface rubber without rubbing off the window switch oatterns
  1. Cabriolet window switch
    By pbarlow0032 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th January 2013, 11:42
  2. How to replace them chrome window seals without taking out the window frame on a Audi
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th September 2012, 12:57
  3. How to change the window button?
    By savvasgr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2011, 08:38
  4. how to - change window switch?
    By dares_uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2009, 08:33
  5. Side Lights, how the hell do you change them????
    By imported_tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th September 2005, 11:58
