Volks AutosSky Insurance
Results 1 to 10 of 10
    Jul 2005
    scotland
    422
    Clutch Upgrade for s-line Quattro
    hi all,
    with some mods in the pipeline. was wondering how much power and torque can the existing OE clutch take?
    car is 1.8T (190PS) S-line Quattro
    anyone upgraded their clutch? anyone running high power in their B6 quattro?
    imported_bubstar
    Re: Clutch Upgrade for s-line Quattro
    I think Oettinger say upgrade the clutch if putting more than 235 lbft through it. Which pretty well means - Anymore than a Re-Map and you'll need a clutch on a 190ps 1.8t.......! [img]/ubbthreads/images/graemlins/blush.gif[/img]
    You might be as well to ask this in the A3 or B5 section, Kenny. I'm sure some of the S3/A3/B5 chaps can advise you.
    It seems to be a problem on AS that people post tuning questions in their own models section and then it just gets lost......... Which is a a shame when you consider the 1.8t is used in the A3, A4 (B5+B6) and A6.
    I'm not having a go at you Kenny but information would be so much easier to find if tuning posts were posted in the tuning section for the whole of AS to read.
    BUB [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Jul 2005
    scotland
    422
    ok, i just figured the A4 would have a specific clutch so thot someone in this section would know better
    imported_bubstar
    Take a look HERE too , Kenny.
    Jul 2005
    scotland
    422
    oh thanks mate [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Jul 2005
    scotland
    422
    had a little bit of bad news.
    from some research and a company, they reckon going upto and around 300lbft will be too much for the standard flywheel. so the clutch and flywheel will need to be replaced [img]/ubbthreads/images/graemlins/frown.gif[/img]
    imported_bubstar
    Mmmmmmmmm..... That's a bummer. Are they sure? Any second opinions?
    I would've thought the flywheel will be ok.
    BUB [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Jul 2005
    scotland
    422
    the reply
    ""With your A4 i have done some research and we have found that the
    rubber
    fixings inside the OEM flywheel are not suitable to run beyond or
    around
    300lbs of torque (which is probably what you will achieve with the
    eliminator kit) so therefore we offer a complete flywheel and clutch
    assembly to replace the current system.""
    seems like a genuine guy and had recomends
    not had a 2nd opinion tho
    imported_bubstar
    Of course, the flywheel is a dual mass one. I guess the replacement one is solid.......?
    BUB
    Jul 2005
    scotland
    422
    think so mate, but said it would feel pretty much the same as standard
