Results 1 to 15 of 15
    Oct 2005
    bristol, uk
    765
    Can you take key blade, swap transponder to new shell?
    Is it possible to get a new key so that can swap over key blade, transponder, rubber button on remote fob so to make it look newer?
    Researching and potentially looking for a nice S4 B6
    Previous cars: Modded Toyota Celica 1.8 Vvtli, modded mk1 TT, standard mkv r32 dsg
    Current: family wagon diesel
    No Gear
    Dec 2012
    Shropshire
    335
    I'm sure someone on this forum has a b7 key fob configured to work with his b6.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,581
    I have a B7 fob working with my B6. You have to have the right version of B7 Fob, the glass immobiliser transponder capsule has to be be transferred and then a new blade has to be cut as the B7 version is a different size to the B6.
    Once that is done you have to re teach your car all your remotes available with VCDS
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Oct 2005
    bristol, uk
    765
    Sounds too painful for now moving over to the b7 fob, but can it be swapped round to new b6 case, ie is transponder ok to remove and touch
    Can the key be swapped around?
    May 2012
    RETFORD, NOTTS
    1,753
    Yes is can be done.
    if its your only key i strongly advise against removing the transponder, if it breaks your car wont start.
    Pm me your reg and chassis details if you would like a quote for a complete new spare key.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Oct 2005
    bristol, uk
    765
    How fragile are the transponders or sensitive to being touched?
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    208
    Yep can be done, did this on my MK4 Golf. Was pretty straight forward.
    May 2012
    RETFORD, NOTTS
    1,753
    They are glass and usually bonded in...
    Oct 2005
    bristol, uk
    765
    Just had a look on youtube
    Seems straight forward enough
    Any b6 owners have the key fob with the chrome bottom edge?
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    300
    Add craigynett on Google+
    most people use nail varnish remover to soften the glue so the transponder can be easily removed. A new case will cost you a few quid off Ebay. Just make sure you buy 1 that holds the correct type of battery
    Please contact Admin if you wish to advertise your business/services on the forum
    mattyboyc's Avatar
    Sep 2009
    1,224
    I've done both my keys to B7 ones, i found the best way to remove transponder was heating with a heat gun and then simply popped out with a pick tool underneath, just a quick one to note,if you do decide on the B7 route not all ccm's are compatible, i had to put a later version one in mine but all in all a straight forward mod.
    A4 AVANT 1.9TDI 130 SPORT:
    18" RS6'S//TWIN EXHAUST//ALLARD EGR DELETE//AERO WIPERS//B7 KEYS & ENGINE COVERS//BLACK OPTICS //FRONT & REAR S-LINE BUMPERS//TAILGATE SPOILER//S4 HEADLIGHTS,GRILLS & DOOR BLADES//RS4 RARB & PEDALS//FRONT,REAR & FOOTWELL AMBIENT LIGHTING//PUDDLE LIGHTS//FAN JETS//MEDIA SYSTEM//T.V//7" HEADREST MONITORS//REAR BLINDS//REVERSE CAMERA// CRUISE & DIS
    craigynett's Avatar
    Apr 2006
    300
    only 1 certain part numbered B7 remote will work with B6 but only 2002-04 B6
    mattyboyc's Avatar
    Sep 2009
    1,224
    Mine is an 02 and needed a later ccm, i replaced it with one ending in BD.
    craigynett's Avatar
    Apr 2006
    300
    yours is right on the changeover year then
    mattyboyc's Avatar
    Sep 2009
    1,224
    I have a great write up on this mod from Audizine in my subscribed threads but can't seem to post a link to it from my phone.
  1. How do you Take the circuit board off the Audi Key
    By powersurge in forum General Chat
    Last Post: 10th August 2012, 12:09
  2. Can you push back taking delivery of new car from dealership?
    By nshort10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th December 2011, 15:32
  3. Can you change the key holder case?
    By flippin82 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2011, 12:46
  4. Can you just take the mirror covers off?? help!
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2005, 17:04
  5. Need help, can't take circuit board off Key!!
    By powersurge in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2003, 08:03
