phil mcglassup
Hi All,
I've made a start on changing my cambelt but I've hit a problem. All the parts were obtained before starting.e. locking kit, belt, tensioner, water pump etc.
The locking kit that I got is a Laser 3978 for PD engines, my A4 is a 2003 with an AVF engine. The camshaft pulley locking pin fits perfectly however the crankshaft locking tool will not mesh into the ribs of the crank pulley. When I tried to fit the tool against the old timing belt, the pitch of the ribs is a mile out !! The mark on the tool for the timing is at the 12 o'clock position, as it should be.
The local supplier who I bought it from is ordering another of the same kit just in case I was sold a pack with a rogue crank locking tool. As an option, they are also ordering a Laser tool 4199 which apparently is also for 1.9 PD engines, I believe this is the same as tool T10100
Any ideas anyone?
Any ideas anyone?
