Badger5Monster Motorsport
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By quattrojames
Thread: Is this a big Job
    Mar 2010
    125
    Is this a big Job
    So before this Car i have a B5 Bi Turbo, which i blew up and was able to replace the Turbos by myself, so i am not shy of a big job, and i coped well. But now i have picked up a 4.2 V8 Beast that has issues, and again am no shy of getting my hands dirty.
    My question is is this a bigger job than the turbo replacement on my B5?
    The Issue with this S4 B6 is it will run for 15 mins, then it dies, i have the Report, naturally a garage quoted me stupid money.
    Can someone tell me what is the issu, what it entails, and will i be able to do it? , many thanks in advance
    www.therepairgeek.co.uk Laptop spares and repairs
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    You need to decipher those fault codes, and then establish what is wrong with it.
    Category:Fault Codes - Ross-Tech Wiki
    Whether it is a "bigger" job than turbo replacement on a B5 is hugely subjective, least of all dependent on your interpretation of "bigger"...
    Furkz likes this.
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    How does it run for those first 15 mins ???
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Oct 2012
    434
    Depends on what needs doing i was always told that on the bi turbo it was engine out to do the turbos?
    Mar 2010
    125
    Quote Originally Posted by Ian2012 View Post
    yeah it was an engine out on the B5 i have :-)
    as for the question on how the B6 runs, it seems to run ok for that 15 mins, i am wondering if its the tensioners?
    Mar 2008
    Oldham, Manchester
    1,110
    Odd that it should run fine for 15 mins and then just die.... the ECU hasn't got wet has it ?? common fault on the B6
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,618
    Crankshaft sensor? I've heard of these failing when they get hot and work again when cold. We currently have this on a Transit at work and my dad had it on an older Saab, Vauxhalls suffer too.
    2002 2.5 V6 Quattro
    Jan 2014
    East Sussex
    79
    Ive just had to replace a Crank Sensor on a 2004 S4.
    Mar 2010
    125
    just to revive this, as i have been away, so as i said start it up and its running , and did so for about 10 mins, until i switched it off, however i hear a really funny noise in the engine? almost lke a tapping as if something is lose anybody help with this, have the tensioners gone maybe?
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,354
    0:04 suggests your S4 has eaten a dog.
    ... sorry I'm useless when it comes to problem solving.
    Jul 2007
    London
    3,258
    Multiple missfires indicates that the chains are stretched or the tensioners are gone. How does it sounds when starting from cold ? It's a engine out job to do the tensioners in the s4 + parts are not cheap either !
    FOR SALE:
    Mar 2010
    125
    That was it starting from cold, that's how it sounds. is it really an engine out job? i had to do that with my B5 that was a bind
  1. Bargain but is this telly big enough ?
    By DAYTONA500 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 16th September 2013, 21:40
  2. Changing the Dash on a Mk1- big job?
    By Audi_UK in forum TT/TT-S/TT-RS Forum
    Last Post: 29th April 2013, 22:07
  3. exhaust sensor is this a big problem ?
    By bearder2006 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st January 2011, 17:07
  4. Big job to replace all the rear bushes on S3
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2010, 11:14
  5. Is this a big NO-NO?
    By berglin in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2004, 13:11
