Sky InsuranceEM Tuning
Results 1 to 11 of 11
Thread: AllGermanParts
    WeeHector's Avatar
    Nov 2013
    Glasgow
    31
    AllGermanParts
    Just a quick post to recommend AllGermanParts to anybody after parts and stuff for their cars. I ordered a full Lemforder suspension arm set at about noon yesterday and it was delivered at half one this afternoon. The service was excellent, very professional and I found dealing with Jason to be quick, easy and stress free. I shall definitely be using them again.
    Oct 2009
    Hull
    1,433
    and how big was the bank loan lol
    WeeHector's Avatar
    Nov 2013
    Glasgow
    31
    Ha it was a lot less than I expected to be honest, came £450 for the lot.
    mattyboyc's Avatar
    Sep 2009
    1,166
    About £450 i reckon, i delt with Matt last week but went for the Meyle HD kit, again great service but then most people are when your about to part with the best part of £400+ I too though would highly recommend them.
    A4 AVANT 1.9TDI 130 SPORT:
    18" RS6'S//TWIN EXHAUST//ALLARD EGR DELETE//AERO WIPERS//B7 KEYS & ENGINE COVERS//BLACK OPTICS //FRONT & REAR S-LINE BUMPERS//TAILGATE SPOILER//S4 HEADLIGHTS,GRILLS & DOOR BLADES//RS4 RARB & PEDALS//FRONT,REAR & FOOTWELL AMBIENT LIGHTING//PUDDLE LIGHTS//FAN JETS//MEDIA SYSTEM//T.V//7" HEADREST MONITORS//REAR BLINDS//REVERSE CAMERA
    mattyboyc's Avatar
    Sep 2009
    1,166
    He must have replied whilst i was writing mine ;-)
    WeeHector's Avatar
    Nov 2013
    Glasgow
    31
    Yeah true, people are very nice when they are taking money off you. I was really pleased with them though so I said I'd post a recommendation on here for them, customers are only too quick to complain these days but ain't as quick to dish out the praise. The job now is finding somewhere to fit the stuff for me
    mattyboyc's Avatar
    Sep 2009
    1,166
    Make sure you have new nuts and bolts, the top ones will break and you will spend ages getting these out, the Meyle kit came with all new bolts but if the Lemforder stuff doesn't get at least the two top ones before you start the job.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,504
    Yeah +1 for the pinch bolt! Can be a right pain to remove....usually snaps and resulting in removing the full leg to drill it out!
    A good idea is to remove the wheel, undo the nut, spray lots of WD40/GT85 or similar in and around, maybe a few gentle taps on the bolt and see if you can get any movement on it etc. Then do the other side. two days later repeat. and again if you can't get any movement on the bolt. Keep doing it until you get movement. tap bolt in and out. DON'T MUSHROOM THE THREAD END THOUGH!
    When fitting new pinch bolt, use plenty of copper grease on it. Ensure the hollow is full of CG. This will aid you in future if you need to remove again.
    My Dad got a garage to replace a top arm on his S8, labour alone came in at £450 as they snapped the pinch bolt and charged him the time it took them to remove the full leg and drill the old bolt out as they sent it away to be drilled! Shocking. Needles to say he isn't using that garage anymore!
    2002 2.5 V6 Quattro
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    +1 for the pinch bolt.
    I ended up replacing one of my uprights.
    Found it was much easier to remove the shock and top arms (took 5 minutes!) - also makes life easier when removing the inner top arm bolts.
    For the record - I have two spare (from a subframe I bought) with the pinchbolts removed
    mattyboyc's Avatar
    Sep 2009
    1,166
    We just packed the threaded end out with washers put a nut on it and wound it out, you have to keep cutting the threaded end as it comes out as you hit the hub assembly, time consuming job but saves removing the whole unit, the worst part for us was trying to remove the track rod ends these were seized solid so doing these next week.
    WeeHector's Avatar
    Nov 2013
    Glasgow
    31
    Thanks for the advice guys, when I checked the parts it appeared like they all had new nuts and bolts with them but I'll double check to see if the pinch bolts are there as well.
