Results 1 to 8 of 8
    Oct 2010
    26
    Digital clock and milage indicator
    Hi all. Done a bit of looking about cant cant come up with anything.
    i dont have vcds so cant scan for faults.
    Just recently i have noticed that the digital clock and trip milage/milage have gone off. Everything else works fine. It does light up just no digits shown. I have checked the fuses but all seems fine! Help as am at a loose end. Thanks
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    Possibly a bad solder connection somewhere or the LCD screen has failed. Remove the cluster and open it up, check for dry joints or cracked joints and repair or buy a 2nd hand cheap set of clocks, either swap full clocks or remove the display you need.
    2002 2.5 V6 Quattro
    Oct 2010
    26
    Would that cause both displays to fail? I had the radiator expension bottle off to clean it out and when it was put back together thats when it had gone off so thought it might have been something to do with that. By changing the clocks does that affect the Immobiliser etc as a few threds i read says they had to reprogrammed? Thanks
    S4_dan's Avatar
    Jan 2006
    1,600
    VCDS should code it fine.
    I can't see how the radiator expansion cap would be related to it. It might be a dodgy connection then. Cluster is easy to remove. Use the search function and find the guide. Or look here: A4 avant electrical problem
    Could be plug not seated properly, bad joint and corrosion.
    2002 2.5 V6 Quattro
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    have you got DIS ?
    if you have you may have turned the display off
    Oct 2010
    26
    Ok thanks for the advice. I'll have a look and remove it to inspect it. Thanks.
    Oct 2010
    26
    No the car doesnt have dis. Its a 2003 a4 estate without it.
    Oct 2010
    26
    Another thing i was just thinking was i removed the bung from under the battery ase the compartment where the battery sits was full of water. I did this on sat and today (sun) it stopped working.
  1. Zada Tech dashboard integrated clock and boost gauge.
    By vrbob in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2012, 18:11
  2. Digital clocks
    By ScottD3 in forum General Automotive Chat
    Last Post: 4th December 2011, 20:53
  3. 2 questions - Cambelt replacemment and Service Indicator question
    By Smudge973 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 1st September 2011, 21:57
  4. 8p3 clocks and switch
    By *Müllërz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2011, 00:23
  5. Interior lights and comfort indicators
    By antnee in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2011, 00:32
