Volks AutosChris Nott
Results 1 to 10 of 10
    technics100's Avatar
    Feb 2004
    Co Antrim
    776
    exhaust drone a 2000 revs - 1.9 tdi
    I'm getting a drone from my exhaust from 1800 - 2000 rpm. its only there and in every gear. anyone else ever get this? At first i thought it was a loose heat sheild or similar, but now definately sounds like exhaust drone...
    Jan 2006
    UK
    99
    Re: exhaust drone a 2000 revs - 1.9 tdi
    Hole somewhere, or something other than heatshield vibrating off something else?
    Loose exhaust rubber somewhere?
    Apr 2009
    76
    i hope someone can come up with a fix as mine is doing it too. tried allsorts
    52 Audi A4 Avant B6 1.9 TDi 130
    Aug 2010
    1,540
    does the exhaust shake excessivly on tickover? the flexible part of the frontpipe can start to seize up causing this and the droning your on about.....
    Apr 2009
    76
    will check that out tomorrow and report back
    deanski's Avatar
    wax on, wax off
    May 2010
    Lancashire
    374
    there's a couple of threads about this and I thought it was my injectors! but it now seems the sound is coming from the back. it tend to stop after the car gets very warm?
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Quote Originally Posted by murran View Post
    What flexi part of the front pipe
    there isnt one .
    chrisash32's Avatar
    Manchester
    575
    yes, this is likely to be the case. It was mentioned on my MOT and i get the same noise at the same RPM.
    To find it, look under the bonnet just behind your turbo. you will see the down pipe going to the exhaust will a flexible bit of pipe. This is the bit that is going on mine.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    have you changed your tyres? these can drone at certain road speeds. Just a thought
    simon.m's Avatar
    Oct 2009
    2,746
    Quote Originally Posted by paul20v View Post
    there isnt one .
    think he means the wier mesh looking bit where it comes up to the turbo mate
