I've fitted some 17'' alloys from an S3 which has completely transformed the handling. Chuffed to bits! However because of the different offset I need some 15mm or 20mm spacers. I've never bought any before so 2 questions please. I understand there are 2 types, some spacers bolt to the hub in which case you use the old wheel studs to bolt the wheel to the spacer. Other spacers have hollow guide sleeves so you obviously then need longer wheel studs to reach through to the hub.
Which type is considered better and where to buy them?
Thanks, Mark.
Thanks, Mark.
