VagCabby
Has anyone had this issue?
On my way to work (30 mile drive) I was about half a mile from my work and I got a sudden strong smell of diesel coming from my car, parked at work and looked under the car and diesel was ******* out from the engine bay. Popped the bonnet and it was smoking, pulled the engine cover off and noticed that the V of my engine block was filled with diesel. After thinking a fuel line had burst I noticed a bolt similer to a sump plug sitting in the V of the block, looked on the side of the fuel pump and there was a hole for this sump type plug to fit into. Fitted it back I and tightened it up and all is well not more leaking fuel.
question is, what would have caused the blacking plug to fall out (threads were fine) the pump is origional from new so I dont see how it would have come loose unless someone has removed it in the past and not fitted it correctly. I had my timing belt and tensioners done 5k miles ago, would they have touched this blacking plug then? Is it a bleed plug for the fuel system? Its located half way down the pump on the left side if your looking from the front of the car. I was lucky nothing set alight!
