EM TuningMonster Motorsport
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    Remap and whistling turbo....
    I'm looking at a custom remap for the old girl. BUT. My turbo whistles. Although I recently stripped and cleaned the vanes it is still has no power/torque below 2k rpm, but is like a scalded after 2k rpm.
    I've got a gutted pre-cat to go on and I will be gutting my main cats too before the remap.
    Would changing the turbo for another alter the way it runs after a remap? It would be a similar turbo, just a later part number. Mine is 'F' and would be looking at fitting an 'S'
    Does anyone know of a good trusted mapper in Yorkshire? preferably one who has a rolling road for before/after. My budget is £300 max as I need to reserve some cash for a replacement turbo.
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    374
    If it's on it's way out I wouldn't even bother until you have replaced the turbo tbh.
    Made on the red side of Manchester
    Nov 2013
    Heath Hayes
    951
    As above sort out the issues before committing it to a dyno. If there's anything wrong with it then it's likely to go bang on the rollers.sounds like you have a boost leak or a problem with the VNT control mechanism, either N75 or vacuum pipes.
    Any tuner worth his salt won't touch a car that has a problem as a map and a run on a rolling road could potentially kill it.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    S4_dan's Avatar
    Jan 2006
    1,600
    I've been told its the bearings in the turbo that is causing the whistle. There is absolutely minimum play in the shaft, no smoke at all.
    Vanes working fine as is the actuator. From reading a previous post on here someone with the same issue solved it by adjusting the actuator rod. Could be the same issue I have as I don't know if it's the original turbo or not, only that the P.O. stated it had always whistled since he bought it in 2006.
    I wouldn't let someone remap her without giving her a health check first. At least if there was an underlying issue they would hopefully be able to pinpoint it.
    N75 isn't throwing any fault codes, car ECU is clean on DTC's.
    As for boost leak I have tried looking and everything seems legit. The whistling starts from 1200rpm when the turbo is spooling, it doesn't get any louder when more boost is applied. No apparent boost 'leak' noises can be heard other than the whistling. Although on an old Saab 900 turbo we had it did this, replacing the turbo solved the whistling but again there was no play in the shaft of that unit either.
    Dan
    2002 2.5 V6 Quattro
    BRILLO's Avatar
    Sep 2011
    Juniper Green, Edinburgh, United Kingdom, United Kingdom
    137
    My 2.5 turbo whistled when I bought it as well. Got 40,000 miles then it got really noisy. It even whistled at tickover. Got new turbo before Xmas. No more whistling.
  1. HELP... Badly whistling turbo and low MPG????
    By Quattro180 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd February 2010, 20:47
  2. here are power maps of chipped and big turbo cars
    By dunk in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2005, 18:37
  3. Question About Boost and Twin Turbos
    By pipewerkz in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th November 2004, 00:35
  4. Remapping and insurance - UK
    By imported_bearboy in forum Detailing
    Last Post: 16th August 2004, 12:07
  5. LLTEK's new D-BOV for Audi, and stock turbo
    By rafA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th February 2004, 14:27
