Monster MotorsportVolks Autos
Thread: cold running
    tbs
    Nov 2012
    44
    cold running
    My 1.9 tdi 130 110k is just that bit more prone to bogging down now when i pull away from standing start. ( I have stalled it and the wife also thinks its not great when its cold) It can be overcome with more throttle but i think somethings not quite right. All good when warm. Its due for service now so what should i get looked at do you think.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,422
    Check the glow plugs
    Mike
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    538
    Give it the italian tune.
    Stick some millers ecomax diesel treatment in,after about half a tank (once dose has run in) rev it red line for about 15mins to give ur system a good clean up. It mgt help.
    1.9 avf 6 speed. Bv43 turbo. Swifttuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    302
    Fuel filter/ glow plugs try first.
    If it's still happening vcds it.
    Mines the same, just let it warm up a bit first
    03 Mig blue 1.9tdi 130 saloon:- GMBH front, dark tints all round, fk coilovers,
    BMW TIGERCLAWS 19" 9j front + 10j rear, debadged rear. HIDs 6k, egr delete
    cominig soon:- votex rear,front end respray, parrot kit, remap, full paint correction
  1. Cold running query
    By macpdm in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2011, 17:35
  2. Cold running issues, Thermostat or temp sensor?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2007, 14:06
  3. A3 1.8T - Cold running problems
    By jiffi77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2006, 16:00
  4. Cold running problems
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2006, 11:54
  5. Oil running too cold?
    By pipewerkz in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th January 2005, 13:30
