Chris NottMonster Motorsport
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By S4_dan
  • 1 Post By S4_dan
Thread: Thats one way to stop warning lights
    Jan 2014
    21
    Hi I'm a newbie to the A4 B6 Cabrio.
    Just purchased my first a 2003 2.4 v6 with a declared fault with the roof and a non functioning central display in the dash cluster.
    Having fixed the roof after discovering various disconnected micro switches and bodges I moved on to fixing the display.
    I used the guide here to replace the central led unit which now works a treat I discovered that the roof warning and ABS warning lights had both been filled with black silicone. Thats one way to stop the lights but why not fix the fault ?
    Have all these cars been tampered with or am I just unlucky ? The car came with a full audi service history and one owner from new but someone who hasn't a clue has been playing with this car.
    May 2012
    RETFORD, NOTTS
    1,707
    Last guy i know who did this wasnt so lucky. he screwed his rev counter up and damaged the pcb trying to cover the engine management light on a late a3 !
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    YSN
    YSN's Avatar
    Sep 2013
    81
    When buying a car you should remember that when you turn the ignition on all of the lights should come on and then go off so if one is not there you should ask questions.
    Nov 2013
    Heath Hayes
    641
    Makes you wonder what else you will find. Codges like this seem to be more common these days especially as a lot of the time you can get warning lights with no apparent problem with the car. Also cars can fail an MOT because of any warning lights that are on the dash.
    Karl.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    What a bodge. Cant stand stuff like this.
    Will more than likely be a £10 sensor causing the light too.
    Jan 2014
    21
    I scanned the car for faults before buying so was aware of the current issues. Just amazed that someone would go to all that trouble rather than fixing the problem
    Oct 2013
    107
    Most tedious matey, my previous car an E60 535d had been neglected for it's last year of ownership, which in turn meant I had a backlog of things to discover and make right. Although it shouldn't it put me off of the car, and bought me back to the VAG
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    149
    Just checked mine today and when you turn the keys in the ignition the lights light up but no EML!
    Nov 2013
    Heath Hayes
    641
    I would get the car scanned for faults, sounds like something is probably hiding.
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    149
    Yeah I will do. How easy do the dials come out is there a how to?
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,505
    Quote Originally Posted by Chrismawa View Post
    Very easy! lift small piece of trim above steering column, remove two torx screws and then gently pull dash up until you can reach round and undo the connectors, one on each side at rear. Lower steering wheel and pull out to full rake to give more room to remove the cluster.
    Have a look here: DIS LCD Replacement - guide
    Dan
    Chrismawa likes this.
    2002 2.5 V6 Quattro
    Oct 2012
    Leicester (LESTA)
    49
    Whenever I purchase a new car, I take a cheap obd scanner with me just incase the lights are 'missing'. Last excuse I had was 'the engine light may have not been a optional extra' when it was missing LOL
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    149
    Quote Originally Posted by S4_dan View Post
    Dan
    Cheers mate. Going to scan it first with VCDS when (or IF) I get it working lol. Then I'll take out the dials and check the light.
    S4_dan's Avatar
    Jan 2006
    1,505
    If you can't get it working and your visiting near Thirsk/York (A19/A168/A1) in the near future, let me know and I'll meet you and scan it for you.
    Dan
    2002 2.5 V6 Quattro
  1. ABS warning, then Oil Level Stop warning, now service light stuck on.
    By casiodan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th November 2013, 23:46
  2. Replies: 4
    Last Post: 28th November 2011, 18:33
  3. My zenon warning light
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2008, 11:08
  4. Boot Warning Light
    By Woodster in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2004, 14:35
  5. ESP Warning Light
    By philyus in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2003, 21:54
