Chris NottVolks Autos
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By quattrojames
Thread: Today's Rant: puncture and Headlight tray fail.
    Wheelmanwayne's Avatar
    Jun 2011
    Birmingham, United Kingdom, United Kingdom
    64
    Add Wheelmanwayne on Facebook
    Driving home and the indicator was doing its nut being intermittent, I know the problem as I come across a thread on here about it a while back. So I get home garage the car hear a hissing from the rear wheel and there's a nail in my fresh 265 that can just legally be repaired, whip the wheel off stick on the biscuit and on to the indicator. Removed my drivers headlamp to clean the connection to the indicator (that old chestnut) and the bottom right hand screw had seized into its metal bracket. I left it to soak and come back to loosen it off and snap the whole corner of the headlight tray snapped off. Not a happy chappy... The punctures not a problem, Does any one know the name or part number to the tray?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I have a spare pair of headlight trays, I'll try and look them out later and post a picture to make sure we're talking about the same thing.
    Wheelmanwayne likes this.
    Mar 2008
    1,053
    Sorry to sound rude here but you got the part number on the tray already and as it's bust you have to take it off so once it's off you can look at the part number ????
    Mini dan's Avatar
    Jan 2014
    15
    would be interested to know this as well as anywhere that sells them as both of mine are broken looks like someone didnt know there was two bolts at the back to undo and just snapped it instead thanks dan
    Jun 2011
    64
    Quote Originally Posted by vr6gordy View Post
    Very true lol I suppose it would help if I used a bit of common sense haha ill whip the light back out and have a looksy.
    I have managed to secure the light pretty well for the moment using a nut and bolt.
    James I think my fix will suffice for now but the man above me with two broken ones seems in need
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    I think they're between £8-£12 from dealers. I bought them and had the same issue as you however I didn't break it, I found it broken (Probably some sneaky garage did it)
    Mar 2008
    1,053
    I know of 2 b6 a4 in breakers near me
  1. Headlight Keeps Failing
    By sebbelcher in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd November 2009, 21:29
  2. Brake and Headlights
    By caz1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st March 2009, 09:10
  3. Automatic Wipers and Headlight defective
    By Kev_M5KPL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2009, 09:04
  4. Got round to fitting H.I.D kit and headlight washers.
    By HOUCH in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2007, 00:09
  5. Todays pictures, all clean and looking good!
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2004, 12:59
