Badger5JMB Retrofits
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By deano1978
Thread: Quantum tuning Bristol
    Searching for 6th gear
    Aug 2008
    South West.
    37
    DPF Removal | Chip Tuning | ECU Remap - Bristol - Automotive Remapping
    Has anyone had any experience of these guys, or have any thoughts on their remaps as I'm looking into getting my 1.9tdi 130 a4 remapped, and came across a guy that works here, through my work. Seems to know his stuff and is mobile which is good. The bhp gain of 159 seems a little low but good torque figures of 380nm. Only other option I've been looking at is Shark performance but its a bit of a trek to the nearest dealer.
    Oct 2013
    185
    Blacksmoke remaps, it's a diy remap and makes about the same results. I did my car and am mighty pleased with it, excellent value for monies.
    Aug 2008
    South West.
    37
    I did read up on blacksmoke, but am a bit worried about something going wrong and bricking the ecu! It does seem very good value for money though.
    Dec 2011
    Somerset
    502
    380nm might upset the clutch by it slipping depending on clutch condition and how smooth the torque curve is on a new map.
    You can get maps with 360nm and 175 bhp to avoid this.
    Oct 2013
    185
    Agree that's part of the reason I went with that remap, not mega aggressive or maxed out torque of the components.
    You're right it is a worry bricking the ECU but I thought I would be ok as I took the recommended precautions of attaching a battery charger to the car, made a backup of the ECU and then flashed it with the new stuff.
    I found resetting all adaptations after and then driving until up to temperature got the most out of the remap too.
    Aug 2008
    South West.
    37
    I'm defiantly going to fit a new clutch, as mine is getting 'tired' so hopefully shouldn't' be a problem. Before I enquire does anyone know if Shark do a mobile service? I'm also going to look into what sort of job a diy blacksmoke map is and what leads/cables will do the job.
    Dec 2011
    Somerset
    502
    What's your tired clutch symptoms ?
    Aug 2008
    South West.
    37
    Car loaded up in 5th gear, accelerator flat out, the clutch slips slightly as the turbo spools up (2-2500rpm). 6th gear is fine.
    Dec 2011
    Somerset
    502
    Bingo !
    I had exactly the same and a reduced torque remap eliminated clutch slip.
    I put it on a dyno and the torque curve was smooth with a flat curve that held torque for longer.
    Aug 2008
    South West.
    37
    What map did you use?
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    628
    Mine is remapped by experttuning.co.uk and is very good remap.
    They run in team with quantum,who r the actual tuners,so i reccommend them :-)
    JayMc likes this.
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Dec 2011
    Somerset
    502
    Quote Originally Posted by JayMc View Post
    CCCTech , I think it's a tweaked Upsolute map.
  1. Who does the most reliable tuning for a 130pd
    By 18ME in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd November 2003, 16:52
  2. Can you get tuning boxes for SAME tractors??
    By smanning in forum Diesel forum
    Last Post: 17th July 2003, 09:55
  3. Chip tuning
    By Gambba in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2003, 08:19
  4. S3-tuning.de's RS4 style front end
    By paul_b in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2003, 21:53
  5. TUNING SEAT IBIZA CUPRA
    By ooooaudi in forum Other Brands & Models
    Last Post: 24th February 2003, 10:29
