EM TuningAH Fabrications
Results 1 to 12 of 12
Thread: Synchro angle
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    446
    Synchro angle
    Right so just had Paul scan my 1.9tdi
    Awx
    My synchro angle was at 5.0
    Should I adjust it ASAP or just waiting til I get my timing belt done?
    It does sound like a tractor on a cold morning, and I'm sure the tandem pump needs new seals.
    Also does anyone know which measuring block to measure my injectors ?
    03 Mig blue 1.9tdi 130 saloon:- GMBH front, dark tints all round, fk coilovers,
    BMW TIGERCLAWS 19" 9j front + 10j rear, debadged rear. HIDs 6k, egr delete
    cominig soon:- votex rear,front end respray, parrot kit, remap, full paint correction
    pauldazzle's Avatar
    Cardiff
    639
    Synchro angle should be as close to 0 as you can get it.
    Engine measuring blocks 13,18, & 23 are all related to injectors.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    446
    Cheers Paul.
    So should I just adjust the angle ASAP ?
    Or wait til the timing belt is due?
    pauldazzle's Avatar
    Cardiff
    639
    When is your cambelt due?
    Oct 2013
    185
    Ooh how do I test / measure this on VCDS, can I do it with the shareware version?
    Apparently the timing belt was done 10k before I purchased the car, I'm curious to see if it is close or on zero.
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    446
    Moolard - run vcds, measure engine then measuring block 4, it's on the right.
    It's due in about 5k miles Paul iirc
    Il check the service history in a minute.
    I know it's only a few minutes to adjust it. So I was thinking adjusting it, and see if it runs much better.
    pauldazzle's Avatar
    Cardiff
    639
    If it's only 5k away & the engine is running ok i wouldn't bother, but if you do decide to adjust it you only have to move the sprocket tiny amounts at a time.
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    446
    Yeah I seen the videos.
    Looks pretty simple tbh.
    Il check my history and then decide
    pauldazzle's Avatar
    Cardiff
    639
    Yeah it's easy enough, but a bit of a pain having to go back & forwards loosening, adjusting, tightening back up & then checking on VCDS.
    Nov 2013
    Heath Hayes
    951
    I would check the tensioner and belt out to make sure it's looking OK. It only takes a small adjustment to get a good change on the synchro angle and yours is a mile out. Assuming it was close to correct the last time it was changed something must have altered for it to be that far out. I would just get the belt changed, are you getting the water pump done as well. ?
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    446
    Right just checked the service history.
    It got replaced at 137k and hasn't just clocked on 178k today.
    According to the service book It needs doing every 60k.
    So that mean its due 197k.
    (18/19k away from a belt change)
    Yes the water pump, rollers, tensioners the lot will be changed.
    The lumpy starts and slight lack of power have become worse over time although it isn't too bad anyway.
    Just compared to when I bought it (2.5years ago) it was a lot quieter.
    Dereststorm - il do what you said and give it a check over just to be sure.
    I think il adjust the syncro for now though. And see how it runs for a bit.
  1. Angle Sensor
    By imported_Tariq in forum VCDS (formerly VAG-COM) forum
    Last Post: 11th February 2006, 12:48
  2. Angle Sensor
    By imported_Tariq in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2006, 21:08
  3. ANGLE EYES ON MY TDI
    By Mcgough in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th April 2005, 20:51
  4. Throttle Angle Sensor
    By S4Driver in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th November 2004, 18:59
  5. A3 sport front wishbone angles
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2004, 11:17
