Volks AutosJMB Retrofits
    Feb 2008
    Front wheel bearing type rumble but not wheel bearing?
    Hi
    my car has developed a wheel bearing type rumble from the front drivers side.
    The noise seems worse at speed when turning right.
    Ive vet had the wheel bearing changed but the noise is still there and everything has been checked but there is nothing obvious.
    Could it it be a gearbox or diff problem?
    its a 2.5tdi Quattro by the way.
    cheers
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    Unusual for the gearbox or diff to do this. Check or swap the driver's side wheel first. Might have thrown a weight balance or there's a flat-spot on the tyre. Both could cause the noise you hear. Also check CV boot isn't torn or loosing grease.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Mar 2013
    Near Oxford
    404
    if it gets nosier when you turn right that means it's the left wheel bearing as this is being loaded. May have changed the wrong side lol
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,573
    Could be a deformed tyre also as had this on the rear once......new tyre and noise went.
    Spin wheel while jacked and watch for any wobble from the tyre as it spins
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
  1. new wheels borbet type s 16x9
    By Adam Davis in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2013, 20:59
  2. took car to tire fitter, for wheel bearing and cv boot . not good
    By losing it. in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2013, 00:00
  3. Ordered new wheels but not sure now!
    By unikarl in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th August 2011, 12:19
  4. Rear Wheel Bearing - type?
    By S3 Jock in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2010, 18:19
  5. Judder At Speed - Not wheel Balance
    By Fast3000 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th April 2009, 13:20
