Volks AutosAH Fabrications
Results 1 to 11 of 11
    czm
    Feb 2013
    215
    Another RNS E Nav question
    I am wanting to convert from my single head unit in my A4 2004 Avant to an Audi RSN E NAv unit.
    Please could somebody point me in the right direction as to which Audi OEM unit I should be look at getting?
    2004 BEX 1.8T Silver Avant - RTECH Stage 1 Remap - 211Bhp/236ft Torque
    TEIN Super Street Coilovers - BlueFlame Catback with 4'' Slashed/Rolled Tips
    Pipercross AirFilter- RS6 18'' OEM's - 225.35.15 Falken 452
    Jan 2011
    611
    Any RNS-E will work, the only issue is the faceplate, but these are changeable, so you could buy a S3 one and put and A4 faceplate on it….. personally I would go for one of the later MK2 models, part number ends 193 rather than 192…..
    03MY 52 reg 1.9 TDi 130PS Quattro Sport Avant - 170bhp remap, RNS-E+OEM bluetooth, B7 wiper arms/blades, 4300K HID+nightbreakers/LED sidelights, rear tints, new lights all round, new front/rear screens, frt armrest, s-line kit, cruise/DIS, B7 gearknob/aluminium trims, parking sensors, black grilles, RS4 RARB, S4 front end, black 18" RS6 alloys
    Still waiting..... S4 rear bumper, exhaust tips, coilovers, leather recaro's.... phew...
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    637
    Before you start, be aware (you may already know) that you need to change your centre console to accept a double-din head unit like the RNS-E. For this you need to remove the center console entirely so that you can remove the metal single-din holder and replace it with the double-din one.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Quote Originally Posted by benjie View Post
    And you'll have to trim the edges of the climate control panel as it sits lower down when you have the double DIN.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Oct 2005
    bristol, uk
    757
    Wow, sounds like a pain and not plug and play like my mk5 golf that I changed
    Researching and potentially looking for a nice S4 B6
    Previous cars: Modded Toyota Celica 1.8 Vvtli, modded mk1 TT, standard mkv r32 dsg
    Current: family wagon diesel
    Feb 2012
    Glasgow
    228
    I'm lead to believe its fairly straight forward (I hope it is as I'm doing the double din conversion shortly) however as mentioned above you will need a double din cage and either double din heater controls or trim down your existing plus full centre console out! Lots of threads on here if you do a quick search!
    benjie's Avatar
    Oct 2009
    637
    Good point Dave, I think I just the trim behind the ashtray down too?
    p1tse - I used a Haynes manual for the center console removal, very detailed and took about an hour... being careful. It doesn't take too long. But yes, much more difficult than the MkV!
    SmoothAssault's Avatar
    Will design for mods
    Dec 2007
    Cambridgeshire
    788
    I did the double in conversion a little while back. I bought a double DIN climate control unit but ended up just using it to make a template and cut the original one down to size. The double DIN climate units don't have the metal bottom edge that the single DIN ones have, and this metal bit is a pain to cut. The whole lot needs filing/sanding down smooth, especially the metal edge or you'll scratch your centre console when reinstalling it.
    The centre console has to come out as that needs to be cut so it aligns to the double DIN cage correctly. There's a comparison of the single and double DIN consoles here: A4 Centre Console DIN variations | Matt Easom
    Also the ashtrays are different, and I never actually seen this documented anywhere before. The double DIN ashtray has a vertical folding flap that covers the 10mm gap between the base of the climate unit and the back of the ashtray.
    For the single DIN configuration Audi put a plastic base that fits behind the ashtray to create a little cubby hole under your climate unit. You can either cut this plastic base down to fit what will be your DIY double DIN console, or throw it somewhere in the shed and find a double DIN ashtray.
    I didn't go for an RNS-E, I just put a concert III unit in but I found it took a LOT of force to get it to slide down the slots on the cage. I had thought I had cables in the way behind, but no, there were small metal guides on the side of the radio that seemed to be a little fat for the slots in the cage. Nothing a considerable amount of brute force couldn't fix.
    Couldn't be happier with the result though...
    FOR SALE: Eibach Sportline Springs from B5 A4. £50 - PM for details.
    Apr 2012
    lincs
    210
    RNS mkII - Its the interior mod for a b6 IMHO
    see mine: RNS-E 2011 Mk2 LED in my 2.5tdi QS
    if you want the how to guide (single to Ddin) pm me with an email addy
    cheers
    And
    A4 2.5 tdi Q sport '02 AKE, "minor modder", 18x8's S4 Avus , Zender Monza's 18x8.5's, aero wipes, interior trim, dis and cruise, real s4 mirror caps, rns-e led, dble din, VCDS owner-learner - GMBH next
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Quote Originally Posted by p1tse View Post
    It can't be plug'n'play when you change a single DIN unit over to a double DIN unit.
    If you already had a double DIN, like a SYmphoiny II, then it would have been plug'n'play - with the correct wiring adapter, antenna adapter and 5 minutes of coding wuth VCDS.
    Jan 2011
    611
    I've done it and it's not that much of a PITA, plenty of guides on-line from others…..
  1. yes another RNS-e, SDS, PTT question....
    By Sno in forum Satellite Navigation
    Last Post: 1st January 2010, 11:29
  2. yes another RNS-e, SDS, PTT question....
    By Sno in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 31st December 2009, 12:26
  3. Another RNS-E & AMI upgrade question
    By sje_123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2009, 18:47
  4. Another RNS-E TV question...
    By Lapchien66 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2009, 19:24
  5. Another RNS-E / Nokia phone question?
    By Keef in forum In-Car Entertainment
    Last Post: 12th January 2008, 17:01
