Sky InsuranceBadger5
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By CHEZ
Thread: Too Much Oil and White Smoke on Startup
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    203
    My local garage changed my oil and filter 2 weeks ago. Checked the oil and its been overfilled. The pic below shows the current level on the stick. Do you think this will be ok or need taking out?uploadfromtaptalk1390139012645.jpg
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,601
    I'd personally drain some out and get it right although a small amount over the mark shouldn't cause any issues. It's when its a good litre or so over it causes leaks to occur.
    2002 2.5 V6 Quattro
    Jul 2007
    770
    Its not very clear in the pic but if its more than a few mm over and you don't use much I would take some out and don't go there again
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    203
    Cheers. Its started smoking on startup since the oil change. Is this the car burning the extra off?
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    203
    Reading around there isn't any certainty what the white smoke is from? The smoke only happens on a cold start and stops once the car is warm. Could this be glow plugs? The car is also rough starting on cold start.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    The white smoke could be steam from condensation built up in the exhaust when cooling down - which is more noticeable in the colder weather and completely normal.
    If it is smoke, than it will linger around.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    203
    Quote Originally Posted by AlexGSi2000 View Post
    I think it is smoke like as its a bit smelly as well.
    Jul 2007
    770
    White isn't oil that's blue.Quite normal for some on cold start.Is it diesel?That will always smell.A little extra oil isn't a worry only when is a lot and there for long
    Dec 2013
    Caerphilly
    58
    On a cold day mines a bit rough and the steam can sometimes look really bad.....if its a diesel like mine it stinks too, so I don't think you have anything to worry about.
    Dec 2013
    Caerphilly
    58
    mike b beat me to it.
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    203
    Cheers guys. Yeah its a 1.9 TDI 130. I'll keep an eye on it - hopefully just the colder weather at the moment!
    Jul 2007
    770
    You need to watch it if you think it different since the oil change.Probably coincidence but it shouldn't get worse and white exhaust should drop as it gets warmer.Wouldnt be surprised if they spilt some oil and that may be burning off somewhere.This type of job is often left to the boys to learn on
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,755
    a good way to remove oil is to feed a pipe down dip stick tube connected to fat syringe and draw it out this way!
    i had to do this on my a4 when i first got it it and overfilled by about half a litre!
    it smoked a lot at the time too!
    Chrismawa likes this.
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    432
    Visit krisavant's Instagram Channel
    Just to add, my 1.9 diesel also chucks out a lot of white smoke on cold mornings when first started and so did my 1.9 diesel vrs.
    Perfectly normal to me.
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    203
    Cheers for the info. It may be coincidence, but I just don't remember seeing this happen before the oil change. Ill see how it goes, may try the syringe method above to remove some oil and get it down to the exact level.
  1. White smoke - Too much oil and error code 004243
    By Nickl in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th May 2012, 08:51
  2. Help! too much oil in a4 b5 1.8 t 2000
    By D shift in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th May 2011, 01:31
  3. too much oil in my tdi
    By andy16vturbo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th March 2010, 19:01
  4. Too much oil??
    By Junior Senior in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th June 2009, 21:50
  5. my car burns too much oil!!!
    By stephen in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2007, 19:14
