EM TuningVolks Autos
Results 1 to 10 of 10
    Jul 2013
    east cornwall
    tailgate water ingress
    hello all,
    have just raised the tailgate to load stuff and a substantial amount of h2o poured out of the joins on the interior of the tailgate.i have just looked up how to remove the trim but thought i would ask if this is a common problem and where might this be coming in,before i start a major disassembly of the rear.
    any help appreciated.my car is an a4 avant b6.
    thanks.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Is it rain water?
    The screenwash pipe often splits in the tailgate compartment, either by the motor or at the hinge point.
    Aug 2011
    194
    Worth reading this - Water in Boot - Any Ideas?
    Jul 2013
    east cornwall
    thanks.....i have just checked the rear screenwash and its not working as it should so youve given me a likely culprit.
    will report back when i do the job,although it might be a couple of days as its pppppissing down in cornwall.
    cheers
    Aug 2011
    194
    Pop the jet assembly out of the rear and see if you have a decent flow thro the spindle - the jets clog - - -
    The motor is known for failing internally as the spindle pipe can break and/or the seal where the spindle rotates can fail. Very, very poor design.
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    For me it was water getting in via the high-level bootlid light.
    Popped the light out and applied a bead of black sealant, pushed the light back in. Did this 6 months ago, seems to have stopped the water ingress.
    *WANTED* AUDI CD PLAYER
    Jul 2013
    east cornwall
    update.......finally managed to remove the trim,(a twat of a job) and the pipework to the washer looks intact and the pump is making suitable noises but no water coming out or leaking into the tailgate itself but no flow out of the jets either, how do i remove the jets to clean them(have tried poking a needle in).also will now have to look for another source of leak such as the hi level b/light.
    Jul 2007
    770
    The nozzles just pop off with a flat bladed screwdriver.Best way to clean them is with a can of air blaster.If theres still no jet with the nozzles off you have a serious leak back in the line and you should be able to hear where
    Nov 2013
    49
    Hi had same fault with my a6 avant 2006 audi did an upgrade on the rear pipe f/o/c as a recall so mut be a design fault
    but also took rear lights out cleaned seals no more leaks touch wood
    Jul 2013
    east cornwall
    update.....all done hopefully.getting the liner back on was a pig to do singlehanded but got there in the end.took off and cleaned the washer nozzles and all is now working,also put a line of sealant along the upper brake light housing so no chance of water getting in there.many thanks for your tips guys...much appreciated.
  1. Water Ingress into Footwell
    By heidi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th July 2012, 09:48
  2. Rusty Sills/Water ingress
    By Padwick in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th April 2012, 19:18
  3. Golf mk4 drivers foot well water ingress
    By aky20 in forum Volkswagen and other VAG
    Last Post: 26th November 2011, 17:12
  4. Battery Compartment Water Ingress
    By Gibonz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd November 2010, 19:39
  5. Brakes, water ingress
    By percybigun in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd December 2009, 13:03
