EM TuningBadger5
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By yendall24
  • 1 Post By Jimmy TDI
Thread: How to Check Anti Shudder Valve?
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    194
    I'm not sure if my ASV is functioning correctly, as when i switch the car off I'm getting like a shudder/judder. Is there anyway I can check to see if its working ok?
    Mar 2007
    salford gtr manchester
    564
    hi which engine do you have in your car
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    194
    Quote Originally Posted by yendall24 View Post
    Sorry I should have put that, its a 1.9 TDI (AWX).
    Mar 2007
    564
    ok the anti shudder valve is a black plastic pod with a black plastic plunger coming out of it its attached to the egr valve what you need to do is get someone to switch the engine off whilst you look at the plunger if the plunger shoots out it is working . if it does not shoot out when the engine is turned off that is because the rubber diaphragm within the plastic pod as split this split is usually caused by engine oil vapour from the egr getting into it and and perishing the rubber . the bad news is audi do not sell this part on its own you have to buy the whole egr valve that said i got mine off ebay for 40 quid hope that helps
    Chrismawa likes this.
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    194
    That's great thanks! I will check it at the weekend.
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,310
    Forum member @udi A3 checked mine in vag-com... to which my car choked and died so think mines pretty clogged haha.
    mikeygulley's Avatar
    Aug 2013
    Paignton, Devon
    30
    Add mikeygulley on Facebook Add mikeygulley on Google+
    Also check that the vac pipes aren't perished or disconnected and maybe check the wiring to the actuator. Mine wasn't working and it turned out to be a broken wire.
    whinfs's Avatar
    May 2013
    Barnsley, UK
    34
    could someone put a pic of the shudder valve and where it is please? mine shudders when turned off but i've never heard of this...
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    194
    I know this is a different engine layout but its the black plastic pod attached to the EGR valve
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    374
    The EGR could be that clogged that the valve can't shut fully, which would stop it working correctly, and totally eradicating engine shake.
    You could just pop the pipe off to look inside to see if this is the case.
    Made on the red side of Manchester
  1. Anti shudder valve problem?
    By pauldazzle in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th March 2013, 19:07
  2. tdi bkd anti shudder valve
    By bigal23 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th October 2012, 01:09
  3. Anti shudder valve problem
    By Oddie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th August 2012, 17:25
  4. EGR and anti shudder valve removed and cleaned. Coated!!
    By Wats-on in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2012, 21:44
  5. 1.9 tdi anti shudder valve
    By yendall24 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th July 2010, 21:22
