Volks AutosChris Nott
Results 1 to 11 of 11
    Oct 2013
    23
    Fuel Gauge Issue
    Hi all.
    I've read lots about the fuel sender unit playing up in Audi's. Mine seems to work about 50% of the time. Sometimes not moving at all, sometime showing the wrong reading and sometimes showing the correct reading.
    The thing that I'm confused about is that my range in the DIS and the fuel warning light always works correctly. Could this mean my gauge is faulty or does the calculation displayed on the DIS not come from the level given by the fuel sender unit?
    Its a Tdi 130 if that makes any difference.
    Cheers chaps
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,605
    Have done a dial test? There is a way of making all of the dials move in sync from bottom to top and back again. Think it is done via VCDS rather than the dash buttons.
    2002 2.5 V6 Quattro
    Oct 2013
    23
    Thanks, No I've not tried a dial test. What is VCDS? is that the diagnostic software?
    S4_dan's Avatar
    Jan 2006
    1,605
    VCDS is Vag-Com Diagnostic Software. Google VCDS and it will lead to a Rosstech website, the makers.
    If you don't want to pay for the full activated version, you can buy the Lite version ($99) and use a copy lead from eBay (£12) but uses are limited. It will scan most modules and do some tests and edit some parameters.
    Dan
    2002 2.5 V6 Quattro
    Oct 2013
    23
    Thanks Dan I will look into that.
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    374
    Quote Originally Posted by S4_dan View Post
    Do you know how to do this as mine sometimes drops 1/8 from one journey to the next, but it only tends to do it for the first half of the tank when I fill it up.
    Made on the red side of Manchester
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    You can't do this on the B6 or B7...with VCDS or anything else, the firmware just doesn't exist in the instrument cluster to do it.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    374
    Well that's sorted that out
    S4_dan's Avatar
    Jan 2006
    1,605
    What dash is this then? B7? It's not the same as my B6.
    2002 2.5 V6 Quattro
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    It's not the same as my B7 either. Looks more like an A3 to me.
    S4_dan's Avatar
    Jan 2006
    1,605
    When the wife comes back I will check if I can do an output test with my A4.
    Dan
    2002 2.5 V6 Quattro
  1. Help required with 2006 A6 fuel gauge issues
    By decky1968 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 23rd March 2013, 23:44
  2. Audi A3 1.6 Fuel Gauge Issue
    By Borbon in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2011, 00:26
  3. Fuel Gauge Issue
    By Tooks in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th February 2011, 21:13
  4. A3 Speedo/Fuel gauge issues
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2010, 19:21
  5. Fuel Gauge issues
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2008, 13:57
