AH FabricationsChris Nott
Thread: Advice please?
    Sep 2013
    Advice please?
    Hi guy's
    I'm after advice please i have a A4 B6 2002 and whilst driving along a road I hit a pot hole front drivers side wheel, immediately after that it seemed that something broken as the engine noise changed and sounded as if the exhaust had fallen off and also whilst on idle the vibration on the car is immense
    I took to a local garage and a quick look by the mechanic who informed me that the cat which goes into the manifold was leaking with mechanical background the worm went ahead after collection the car still sounds the same vibration, engine noise as if the exhaust is broken and also when I change gears air is releasing from somewhere as if I've got a dump valve fitted which I haven't.
    Any advice to what I should look out for will be appreciated as garages charge but do not confirm that this the exact problem.
    Thank You
    Feb 2012
    Glasgow
    221
    Hi it might help if you give us a bit more info like what engine you have?
    Sep 2013
    Hi Ian it's a 1.9tdi Sport
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,566
    Check all inlet pipes and exhaust system for any loose connections or holes.
    2002 2.5 V6 Quattro
  1. S3 advice please
    By V5Ade in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2004, 22:13
  2. S4 Advice Please
    By azzurro2222 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th June 2004, 20:12
  3. advice please
    By stv in forum A8/S8 forum
    Last Post: 10th June 2004, 13:25
  4. Ess Three advice please...
    By wizard in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 21:45
  5. Considering buying an S3 - Advice please!
    By Rich1275cc in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2003, 08:47
