Badger5EM Tuning
Results 1 to 11 of 11
    IANF67's Avatar
    Jan 2014
    36
    A pillar trim removal
    Any tips on the removal. Need to route my microphone wire up and over. I'm assuming it will clip off but is there a good place to start the process
    cheers
    Dec 2006
    barnsley
    1,016
    you ll need to remove the grab handle above the driver to remove the a pillar trim itself
    2 screws which are behind 2 locking plastic tabs on the handle itself
    then lift the a pillar upwards and into the vehicle
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Can you not just pull back the rubber seal and poke the wire under the trim that way?
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    There is a screw under the cover that says Airbag and then remove the 2 screws holding the grab handle and also remove the sunvisor and then pull it off
    Jan 2014
    The screws are going to be Torx 20 and / or Torx 25 size.
    IANF67's Avatar
    Jan 2014
    36
    Thanks folks. Forgot to mention its a cabriolet
    Sorry
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,003
    Mr Wolf. If you want to advertise on here please contact the admin.
    Do not link to your business in your signature line, it has been removed.
    JSD 2.59
    Synergy-Solutions
    IANF67's Avatar
    Jan 2014
    36
    Have done that quattrojames. Got to the top but need to get round to the front. Was planning on stickin the mic on the inside nesr the windscreen about 6/8 inches down the pillar
    Aug 2012
    Darlington
    172
    Don't run it up behind the rubber seal, run the cable to the back of the dash (access to the fuse panel for feeding it up/down) and tuck the cable behind the A pillar edge closest to the screen. Takes no more than 5 minutes without the need to remove the pillar
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    203
    Glad you asked this as this is exactly what I need to do! After removing the screws and pulling it off - theres no chance of the airbag going off is there??
    IANF67's Avatar
    Jan 2014
    36
    After messing around for a while I've sited the microphone on the cluster it fits snug on the little ledge just under the PRNDS. Looks nice and sounds ok too from what people tell me anyway
  1. 8P C-pillar trim removal
    By ADi Nuff Valves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th September 2011, 21:18
  2. A Pillar trim removal?
    By sachen in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2011, 13:25
  3. Any advise on A pillar trim removal ?
    By sipod in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2010, 16:36
  4. A Pillar trim removal
    By g60leigh in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th June 2008, 19:56
  5. A-pillar trim removal
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd June 2007, 17:30
