AH FabricationsChris Nott
Results 1 to 9 of 9
    Mini dan's Avatar
    Jan 2014
    15
    1.8t bfb misfire with fault codes please help
    Hi there just after a little help and advice I have a 04 audi a4 ltd edition 1.8t 163 I have had it a week now and has a constant what I think is a misfire as when you drive it it vibrates like mad not to bad low in the rev range but the higher you rev the worse it gets any simple ideas of what it could be these are the codes it threw up today ImageUploadedByTapatalk1389561075.286730.jpg thanks for the advice dan
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,596
    Hi and welcome.
    Can't read your codes from the pic very well. Can you please copy and paste/type them onto here?
    Have you checked the spark plugs? Coils sometime fail so it could be a coil pack. There was a recall on coil packs, check that your car has had/had not had the recall.
    Dan
    2002 2.5 V6 Quattro
    Mini dan's Avatar
    Jan 2014
    15
    17698 coolant temp sensor (g83)
    P1290 002 signal to small intermittent
    16891 idle control system rpm
    P0507 001 higher than expected
    18010 power supply terminal 30
    P1602 002 voltage too low intermittent
    18062 please check dtc memory of instrument cluster
    P1654 004 intermittent
    Thanks dan
    S4_dan's Avatar
    Jan 2006
    1,596
    Quote Originally Posted by Mini dan View Post
    Thanks dan
    P1602 & P1654 could be battery. Low power when cranking car. BUT I sometimes get the P1654 code when I turn on my HID lights. Do you HID lights installed? After-market type?
    P1290....try changing your CTS. Does the gauge sit at 90? With engine up to temp, use VCDS to monitor the temp.
    P0507....Not sure. Do the 1.8's have an IAC valve? Check for leaks/drawing in more air than expected.
    When was the fuel filter last changed/car fully serviced?
    Dan
    2002 2.5 V6 Quattro
    Mini dan's Avatar
    Jan 2014
    15
    Well computer is showing service in 7500 miles I have a new cts to go in and my full vcds should be here tomorrow temp sits at 90 compression is all ok I think between 160- 185 dan
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    im having the same trouble im just waiting for replys on my finding on my latest thread lol , anyway try your coilpacks , try audi to see if theres any recalls , i did and got sorted free , there even going to do a 80 point check , bet theres a right list after ha ha
    Mini dan's Avatar
    Jan 2014
    15
    Went in for coils and they wouldn't do them as they have been changed for non oem ones lol
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    ive got 2 coils oem ending in R, and 2 bosch for some reason , im trying to get 2 more genuine failed ones so they will replace all 4.
    Mini dan's Avatar
    Jan 2014
    15
    update on the running issue still as bad as ever have logged the lambda values hoping somone can tell me if im right in thinking i have a vac leak thanks dan
    Address 01: Engine (8E0 909 518 AL)
    17:10:07 Group 011
    1080 /min RPM
    105.0°C Temperature
    43.0°C Temperature
    5.3 °ATDC Ign. Timing
    17:10:07 Group 032
    3.6 % Lambda
    5.5 % Lambda
  1. help with fault codes please
    By teknik in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2011, 14:52
  2. help with fault code please p1847 18255 A3 2.0 TDI 140 BHP REG JULY 2005
    By adiehorrocks in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th August 2011, 21:20
  3. Help with fault codes please - Update : new problem found + video
    By J_V_DUB in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2011, 09:26
  4. Issues with a3 tdi sportback..........fault codes......please help!
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th January 2010, 22:59
  5. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
