Results 1 to 9 of 9
    biyitch's Avatar
    Chocolate? It's doo-doo, baby!
    Southampton
    316
    Water in Boot - Any Ideas?
    I've noticed water collecting in the spare wheel well of my 2004 S4 Avant over the last few months, causing heaving condensation, so I've been trying to work out where it's coming from. I've ruled out the washer system: I didn't use the rear washer for over a week and inside the tailgate trim is dry (where the pump is as well as the upper tailgate section) but the water still accumulated.
    I pulled all the trim out of the floor and it looked like water was getting past the rubber seal on the bottom left-hand side (red ring in photo) and I could see the path of travel along the body (1), under the main floor plastic, soaking the felt triangle underneath* (2), down the body into the well (3) and collecting at the bottom (the 3 pads are also soaking*).
    *Soaking fabric could have been condensation rather than water passing through it directly.
    I bought a new boot seal from Audi for about £60 but that hasn't fixed it (although the seal must be better as the tailgate needs a little extra force to close now). Looking at today's photo the evidence of ingress in the red ring is still present too.
    I've uploaded a few more photos taken today of the tailgate area. I was hoping someone could let me know if there's any trim/sealing parts missing. Most the wet parts of the tailgate area are just where I opened it at lunchtime after this morning's rain but you can see water on the trim of the tailgate where it seems to be coming in.
    IMAG0291.jpg IMAG0292.jpg IMAG0293.jpg IMAG0294.jpg IMAG0295.jpg IMAG0296.jpg IMAG0297.jpg
    Audi S4 Avant (B6, 2004) in Goodwood Green.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,569
    I would say the rubber seal has become flat over time and does not sit tight to the tailgate.....experiencing a similar problem on the wife's mk5 golf and had the same prob on my old Lupo GTI.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    biyitch's Avatar
    Southampton
    316
    Well that's the thing - I replaced the seal and the fit is now tighter but it's still leaking.
    Feb 2012
    Glasgow
    228
    I reckon it is a split in the hose from the washer bottle to the rear scoosh. I'm sure that hose runs behind the plastic hinge cover in pic 4 the one with the arrow shaped hole in it and can split because it's a movement point.
    biyitch's Avatar
    Southampton
    316
    I'll have a look. Thanks.
    Aug 2011
    196
    I'd suggest thinking outside the box a little on this - is there any evidence of water in the actual hatch itself? I had a similar problem which turned out to be the seal around the high level brake light allowing water into the hatch. This then drained through the bungs at the bottom of the door, leaving a witness mark just like yours. You could actually hear the water running around inside after the car had been washed. Sealed the light - problem fixed.
    As has also been suggested, the water pipe can be another culprit - or the pipe which runs thro the rear wipe motor. Getting the cover off is a bar-steward of a job, but can be done - see avant bootlid plastics removal info req! for advice on this especially lovely job!
    Mike.
    Jul 2013
    east cornwall
    thanks mike b. will check that as well...cheers
    Dec 2006
    barnsley
    1,016
    check the rear wash wiper isnt leaking into the boot
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Rear light seals fail and fill the boot. I've just had mine done cos of this problem. Bone dry now :-D
  1. Boot opens when i start the car, any ideas?
    By A3 steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2014, 20:53
  2. Rear Windscreen wiper stuttery/water jet not working-any ideas?
    By jnielow in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2012, 12:50
  3. Sudden Water leak any ideas please ?
    By Lings in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th March 2011, 14:53
  4. a3 leaking water into car ?? any ideas
    By nick1973 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2007, 12:41
