EM TuningBadger5
    Oct 2013
    185
    1.9 tdi vacuum pipes
    Afternoon! I had a bit of time to spare after bleeding my,brakes today so I went to replace my vacuum pipes with silicone stuff that I had bought ages ago. The upper ones weren't too bad to replace by removing the drivers headlight and the air intake ducting, but two things:
    The turbo actuator solenoid is really hard to reach! Is it easier to reach from the underside? I'll have to try that another day.
    The turbo and EGR pipes look thicker and shaped for the job, I opted not to replace these as they looked in great condition.
    Has anyone else done this?
    Dec 2013
    Caerphilly
    58
    I replaced the pipes I could reach. As regards to the N75 I managed to get a ratchet down between the timing belt cover and radiator and undid the two bolts holding it on. Then its free enough to take the pipes off. There was one pipe that seemed to run down under the engine from here which I couldn't trace or reach so left that one. I deleted my egr and just stuck a bolt on the end of that vacuum pipe. Its 5mm if I recall. And the rest are 3mm.
  1. Replies: 5
    Last Post: 12th March 2013, 23:14
  2. mistery resistor and disconected vacuum pipes
    By yendall24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th November 2008, 21:24
  3. Audi 80 Tdi Vacuum Pipes
    By ghee60 in forum Classic Audi Forum
    Last Post: 25th November 2007, 19:46
  4. 1998 a6 1.9 tdi vacuum pump replacement - how hard? where is it?
    By evomaster3000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd September 2005, 11:53
  5. 2.0 TDI exhaust pipes by PowrFlow
    By philinman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2004, 01:55
