Chris NottBadger5
    Scotsmann1's Avatar
    Sep 2013
    East end
    66
    Alternator replacement
    Alright guys how easy is it to replace my alternator on a 2004 b6 Audi a4 (190) I've had a look was wondering if it's just the 4 Allan key bolts that have to be taken out and new 1 put in .
    Dec 2013
    23
    First of all draw a diagram of the belt configuration, put a bar on the tensioner, pull towards the near side, pull belt off alternator, undo 4 Allen key bolts, two at the top and two at the bottom, undo 13mm nut at rear of alternator, remove cable, then remove plug then remove the alternator. To put new one in do this in reverse. Remember to connect leads before bolting up. Hope this helps.
    Scotsmann1's Avatar
    Sep 2013
    East end
    66
    Cheers for that bud
    Scotsmann1's Avatar
    Sep 2013
    East end
    66
    Woohoo that's it done
  1. 2003 2.5TDI Avant Alternator Replacement?
    By terryp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th February 2013, 11:58
  2. Replacing my alternator
    By skinnyman9000 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th February 2011, 15:43
  3. Alternative Replacement for the S3
    By Audi_Alex in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2009, 13:40
  4. Concert II Replacement / Alternative
    By Audi-Bob in forum In-Car Entertainment
    Last Post: 26th May 2008, 22:18
  5. Alternator replacement
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th August 2006, 19:20
