Badger5Monster Motorsport
Results 1 to 7 of 7
    Mar 2008
    1,058
    head lights adjuster
    can anyone tell me witch adjuster i need to move as my headlight are now to low from lowering car is it the adjuster nearest the wings for up and down or is it the other for up and down ??? i dont wanna try move it cos the left and right is set bang on
    spirit's Avatar
    Nov 2013
    kings lynn-norfolk
    22
    Visit spirit's Instagram Channel
    Up and down is the one central one buddy
    Jan 2013
    Bracknell, Berkshire
    48
    I recently did mine but can't for the life of me remember which is which! I do remember it being hard to see the left right movement but up down was obvious. You could count the number of turns you do and if you've moved the wrong one turn it back the same number of turns to reset it.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    the inner ones
    Oct 2012
    177
    Hi guys,
    Sorry to highjack a thread here, but my height position is spot on however, my cutoff for my lights are not exactly straight?
    here is what the xenon beams SHOULD look like ------\---------\--------- mine are similar except the dashed lines are not parallel to the floor? hope you understand what i mean? is there an adjuster which could fix this? or is that just the way the older S3 8ps are designed?
    On a side note, i managed to change the height by turning the adjuster with an alan key hope this helps
    Any information is appreciated
    Will
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    If you have an S3 you'd be better off posting in the relevant section.
    Oct 2012
    177
    Oops sorry my bad, I made a search for adjusting xenons and assumed it was under the 8p sections.
    My bad ^^
    Will
  1. Head light adjusters
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th March 2012, 12:15
  2. Disconnecting automatic xenon head light adjusters....
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 14:29
  3. Head Light Adjuster
    By markymark1984 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2007, 19:34
  4. Head lights INCORRECT adjustment LOWERED S3
    By 242spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2006, 18:54
  5. want to replace head lights on a4 1.8t sports
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2003, 22:15
