    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    203
    Central Front Jacking Point
    Im looking to service my car in the next couple of weeks and I'll need to jack the car up and use axle stands to get under the car. Two questions, is there a central jacking point to lift the whole front end up to allow the placement of stands? While I was searching around someone recommended: Jacking point | Flickr - Photo Sharing!
    Where is best to place the stands?
    ...or should I just get some ramps!?
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    374
    When I did the lower arms on mine last month, and the oil and filter a couple of months ago that picture you linked is where I put the axel stands. I jacked the car up by the strengthened jacking points on the cills of the car using a trolley jack.
    Just put the stands under one side at a time starting at their lowest setting, then raise them one level, and one side at a time until you reach your desired height. This takes a bit longer going from side to side, but is safer than sticking one under at the desired level then jacking the other side up to put the other one in.
    Made on the red side of Manchester
  1. Alternative Front and Back Jack Points for A4 B7
    By zcook in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th April 2010, 15:04
  2. Jacking Points!
    By AS3TOM in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2009, 01:58
  3. Jacking Point - Trolley Jack
    By I'mRonBurgundy? in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th September 2008, 21:10
  4. Help with jack points!
    By imported_MattT in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2004, 11:12
  5. S3 trolley jack points help
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2004, 10:54
