Chris NottEM Tuning
    Oct 2010
    451
    Not sure if problem or not.
    The other day after a lot town driving I noticed the normal biting point felt like the car would stall and a slightly hesitant and vibrate. Therefore required more throttle. I also notice sometimes when I come to stop and move the gear neutral it makes a slight vibration again like it make stall. But there is no drop in revs.
    Anything I should check? I have vcds so I will do a scan. The onboard computer says the car is "OK".
    Oct 2010
    451
    Any advice?
    Jun 2011
    Great Melton Norfolk
    1,356
    DMF on the way out? How many miles it done?
    Oct 2010
    451
    It's done 105k. It rides a little high and it's not slipping.
    Dec 2013
    22
    Mine felt similar to this the other day, turns out one of the engine mounts was no longer doing what it should!
    Oct 2010
    451
    Engine mount will cause me to rev higher to make it move without shuddering so to speak?
  1. Suspect to be A3 Turbo problem(not sure)
    By kennethwsl in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2011, 12:09
  2. S3 problems maybe the diff not sure??
    By Jiny_P in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2007, 13:54
  3. APR or GIAC?? STILL NOT SURE!
    By Maso3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2005, 00:51
  4. Audi breakers (Not sure if correct forum?)
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2004, 15:43
  5. Def. Problem, Car not starting when cold!
    By charTT in forum TT/TT-S/TT-RS Forum
    Last Post: 14th April 2004, 22:10
