Results 1 to 16 of 16
Thread: Genius required
    bob2312's Avatar
    May 2011
    Failsworth Manchester
    41
    Genius required
    1 Central locking stopped working remotely,2 Rear doors don't lock or even show up on dashboard display when opened ,3 When any of doors opened no interior light , 4 Alarm stopped working, only goes off when I have locked doors with key then after unlocking goes off about 20 seconds later,5 The doors have stopped locking when in motion, 6 When I lock the doors with key only the drivers door opens and have to turn on ignition to get front passengers to open,apart from these minor issues car drives perfectly,had at Garage 4 times he thinks the rear locks have gone and is trying to source some replacements, just had serviced and mot so £250 pounds lighter someone out there must have an ides,thanks
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Have you had it scanned for fault codes?
    I would suspect maybe the alarm siren batteries have leaked and fried the PCB, or the comfort and convenience module under the front passenger seat has got wet. Check the carpet to make sure it's dry there, are the drain holes under the battery free?
    Or it could be a multitude of fault microswitches?
    Feb 2012
    Glasgow
    228
    I don't suppose you/the garage have scanned with vcds?
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    374
    I'd go with door locks, or ccm mate.
    I have VAG-COM if you want a scan doing to see what comes up to get a better idea? It would be better than going in blind so to speak, as that can soon lead to wasted money.
    Made on the red side of Manchester
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    Check the wires that go from door to car for breaks, pull back the black rubber boot and check
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    I would go with broken wires inside where the doors hinge or bad connections in the plugs that are in the same area... they can cause lots of different problems... intermittent speaker's, central locking, door light's, puddle lights, interior lights... all go trough this ... I've done repairs on 3 B6's all with broken wires inside the rubber gaiter at the hinges
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    bob2312's Avatar
    May 2011
    41
    Thanks for all your suggestions,will pass them on ,it has had a diagnostic but it was all error codes but did not indicate what was going wrong
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,533
    Quote Originally Posted by bob2312 View Post
    We might be able to help more if you posted the FULL VCDS scan results.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    bob2312's Avatar
    May 2011
    41
    Posted them under How many error codes on Nov 11 no idea how to link to another post I have done
    Nov 2013
    Heath Hayes
    951
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    Nov 2013
    Heath Hayes
    951
    The Ross tech Wiki is a great place for decoding fault codes, especially when you have as many as you have.
    Category:Fault Codes - Ross-Tech Wiki
    Mar 2008
    Dorset
    13,856
    Agreed, plug all those codes into the wiki and see what they diagnose. Here are three straight away that will point towards your issues, broken wires in the door hinge are a good place to start by the looks of it.
    Have you checked to see if the carpet is wet yet?
    For example: 1333 -
    01333 - Door Control Module Rear Left (J388)
    01333 - Door Control Module Rear Left (J388): Defective
    Possible Causes
    Fuse(s) faulty
    Wiring and/or Connector(s) from/to Door Control Module Rear Left (J388) faulty
    Possible Solutions
    Check Fuse(s)
    Check Wiring and/or Connector(s) from/to Door Control Module Rear Left (J388)
    Check/Replace Door Control Module Rear Left (J388)
    1559:
    01559 - Drivers Door; 59-00 Can't Unlock / 60-00 Won't save
    Possible Symptoms
    You cannot lock or unlock the Drivers Door
    Possible Causes
    Mechanical failure in the doorlock
    Mechanical failure is cables
    Short to Groud / B+ in wiring
    Possible Solutions
    Check wiring and connections
    Check mechanical cables
    Replace the doorlock
    1331:
    01331 - Door Control Module; Driver Side (J386)
    01331 - Door Control Module; Driver Side (J386): Supply Voltage Too Low
    Possible Causes
    Fuse(s) faulty
    Wiring/Connectors from/to Control Module faulty
    Power Supply (Battery/Generator) faulty
    Possible Solutions
    Check Fuse(s)
    Check/Repair Wiring/Connectors from/to Control Module
    Check Power Supply (Battery/Generator)
    Special Notes
    When found in an individual control module, it's most likely a local source (e.g. wiring/connectors).
    When found in multiple control modules at the same time, it's most likely a common source (e.g. ground spot, battery, generator).
    Intermittent codes are often stored during low outside temperature when the battery capacity goes down and may be ignored.
    01331 - Door Control Module; Driver Side (J386): Faulty
    Possible Causes
    Fuse(s) faulty
    Door Control Module Driver Side (J386) faulty
    Possible Solutions
    Check Fuse(s)
    Check Door Control Module Driver Side (J386)
    01331 - Door Control Module; Driver Side (J386): Single-Wire Operation
    Possible Symptoms
    Data Bus Comfort working in Single-Wire Mode
    Possible Causes
    Wiring/Connectors from/to Door Control Module Driver Side (J386)
    Control Module in CAN Data Bus Comfort faulty
    Possible Solutions
    Check Measuring Value Blocks (MVB)
    Check Wiring/Connectors from/to Door Control Module Driver Side (J386)
    bob2312's Avatar
    May 2011
    41
    Carpet is dry and no moisture in door either
    Lancaster
    1,780
    There's alot of padding under that carpet. I'd get it lifted and properly check for water.
    To do: None yet.
    Mar 2008
    Oldham, Manchester
    1,110
    I would check inside those rubber gaiters at the door hinges first before I started ripping up carpets... honestly it's a really common problem for the wires to break
    Mar 2008
    Dorset
    13,856
    Agreed, and from the fault codes I've referenced for you it's the most likely issue.
  1. Translator required...
    By munkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2003, 18:32
  2. Graphics Help Required!
    By Moresauce in forum General Chat
    Last Post: 12th August 2003, 10:10
  3. New rear badge - help required
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 21:42
  4. IT Help required
    By danksy in forum General Chat
    Last Post: 19th February 2003, 14:59
  5. New interior required
    By Simon in forum General Technical / How To
    Last Post: 19th February 2003, 11:20
