Well today has been a long day that started off in a rather bad way. I had a delivery that was the completely wrong item, so I had to spend a couple of hours sorting that out.
After that was sorted I took some alloys up to the tyre fitters to get some tyres swapped over so I could do some test fitting of the second set of AMG alloys.
The rears were fine to fit straight on, but I plan on spacing them out a bit as there is still a bit of tuck.
The fronts would fit, but they were literally 1-2 mm away from fouling when jacked up, so began the tedious and long winded task of ringing round alloy wheel centres, and tuners in the Greater Manchester area to find some spacers and longer bolts.
I ended up getting a pair of 10mm spacers from a company in Stockport, and the bolts from Awesome GTI in Irlam.
I think I'm going to put these 10mm spacers on the rear, and order some 8mm ones to put on the front, but for now they need to be on the front so I can run them.
By the time I got home from driving around (in loads of traffic) I was starving and stressed out so I had some tea then cracked on with the fitting in the dark. I only got finished at 8pm so it was too dark for pics, I did try, but the iPhone is pants in the dark.
