Retro fit washers...
gavk75
NULL
Has anyone retro fitted or modified the washer jets on the front/rear of a B6 avant?
The ones I have are stock but one of the washers has a tendancy to veer slightly north of target every once in a while. Instead of replacing the stock washer has anyone fitted the newer (wider) spray jets? Or is it compatible on this model - without replacing the motor etc..
I fitted the heated fan versions from a passat on mine and work loads better than the water pistol type that was on my sport before.
One of the best mods I've done this, very worthwhile. It's a shame the Passat ones need to be bonded in rather than use the same clip in method, but that's the only downside really.
993
7
878
923
