    Jun 2013
    Southampton
    100
    Coil Packs - After Dyno run ABS - Central locking wont de-safe - VCDS errors
    Had my engine light come on tonight on the way home and the car was misfiring. Pulled over and swapped my coil packs and that seems to have got rid of the problem. Just want to confirm that this is the error I'd see with VCDS if a coil pack went?
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 8E0 909 518 AS HW: 8E0 909 018 A
    Component: 1.8L R4/5VT 0003
    Coding: 0011511
    Shop #: WSC 02629 005 00000
    VCID: 810F6328DB7C0C161BD-5164
    2 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - - Intermittent
    16687 - Cylinder 3
    P0303 - 001 - Misfire Detected - Intermittent
    Readiness: 0000 0000
    Coil pack lasted a week after remap and strangely two of mine had already been changed and this was one of the ones that hadn't been changed. I swapped all four for the red top ones I purchased.
    Second VCDS error I have I think is due to the car being on a dyno last week. I have this error:
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 4529
    Coding: 04475
    Shop #: WSC 06435
    VCID: E5C757B87F14C036875-5148
    3 Faults Found:
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    27-10 - Implausible Signal - Intermittent
    18258 - Powertrain Data Bus
    P1850 - 35-10 - Missing Message from ECU - Intermittent
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    I am assuming this is because the ECU saw the front wheels turning around at a ridiculous speed compared to the rears and that is all it is?
    My last error confuses me a little. My central locking appears to function OK but VCDS is giving these errors:
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1412
    Coding: 06859
    Shop #: WSC 63351
    VCID: 73E3B9E041C0AE86991-4B40
    Subsystem 1 - Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0003
    Subsystem 2 - Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0003
    Subsystem 3 - Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0204
    Subsystem 4 - Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0204
    4 Faults Found:
    01616 - Signal Wire to Interior Monitor
    49-10 - No Communications - Intermittent
    00955 - Key 1
    35-10 - - - Intermittent
    01561 - Rear Left Door
    61-10 - Won't De-Safe - Intermittent
    01562 - Rear Right Door
    Any ideas?
    I've cleared all the codes and hopefully they wont come back (Though central locking one I cleared a week ago and it is back).
    Paul
    Jun 2013
    Southampton
    100
    One other question, how long will these coil packs last? Is it always worth having a spare set in the boot of the car?
  1. Replies: 12
    Last Post: 21st June 2012, 14:21
  2. Cheaper coil packs and better running (MarkIV TFSI coil pack)
    By docurley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2011, 13:59
  3. Coil pack recall still running!
    By sminkie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd May 2011, 18:19
  4. Central locking stuck in safe mode
    By darklyte in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st September 2007, 06:39
  5. Help - Coil Pack changed but still not running right!?!?...
    By Jodi in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2006, 19:58
