Volks AutosBadger5
Results 1 to 14 of 14
Thread: Fitting Hybrid
    dale86's Avatar
    Oct 2012
    354
    Fitting Hybrid
    I'm gona be fitting a hybrid to my car in the next couple of weeks it's a 1.9tdi while I'm on I'll be changing oil and filter. Am I ok to use standard oil or is it ideal time to put something different in . Thanks
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,312
    Depends if the term standard means Audi LongLife servicing haha (in which case stay clear of standard oil!), oil's surely the same regardless of turbo in which case any of these will do fine VW - Engine Oil - 507.00 - VW 507.00 motor oil.
    dale86's Avatar
    Oct 2012
    354
    Ok thanks very much.
    dale86's Avatar
    Oct 2012
    354
    Cheers thanks fir the reply
    Jul 2007
    London
    3,214
    You will need a map with the n75 duty cycle modified as the hybrid will make boost in a different way to a standard turbo. It might be ok as it is as the changes are not major...
    FOR SALE:
    dale86's Avatar
    Oct 2012
    354
    Thanks Adamss24 it's the first port of call once all is fitted and running ok I'm trying to find someone locally to me who is good with diesel mapping.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    606
    Did go ahead with this? Who did u map?
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    dale86's Avatar
    Oct 2012
    354
    I havn t yet fitted will be in the next couple of weeks just sourcing the turbo oil feed pipe and gaskets. I was thinking on emailing black smoke to see if he could just do me a temporary map or see why he recommends.
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    374
    Where are you?
    Made on the red side of Manchester
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    606
    dale86's Avatar
    Oct 2012
    354
    I'm in Durham and that's the oil feed pipe I'm getting thanks. It's all coming together now just to find the time between me and my brother fitting me in his work to bolt it up .
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,312
    I know the braided oil feed pipe can be a longer length but is there any other advantage with it?
    dale86's Avatar
    Oct 2012
    354
    It just says the fittings are more robust something about the ones on the car from factory are prone to been a pita when fitting.
    Jul 2007
    London
    3,214
    Quote Originally Posted by DieselJake View Post
    No advantages whatsoever, they only good when fitting larger/hybrid turbo's as the factory oil feed pipe will not be in the same place on a different turbo... The braided hoses also need careful tying and routing to stop them from chaffing onto sharp parts !
    FOR SALE:
  1. Garage In Kent (South East) To Source/Fit Hybrid Turbo + Uprated Clutch?
    By swift in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2012, 12:35
  2. After fitting hybrid turbo.
    By sandwich1987 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2012, 19:27
  3. what else is needed when fitting a hybrid
    By Mpathe in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2011, 14:33
  4. Hybrid Turbo fitting
    By sijones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2010, 12:39
  5. What are Hybrid Turbos and has anyone fitted them to an S4?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th February 2007, 15:07
