Chris NottSky Insurance
    dale86's Avatar
    Oct 2012
    354
    Quattro gearbox oil leak
    Hi all I have a 1.9tdi Quattro with a gearbox oil leak 6 speed its not serious but needs attending . I have steamed it all down and checked where it's source is and seems to be coming from the backend of the box where it looks like it can be split. Am I right in thinking this is the transfer box and is it gona be a hard job. If anyone can help It would be greatly appreciated and if it is a specialist job is their any additive you could suggest that can seal up leaks if it's gona be crazy exspensive thanks .
    Oct 2012
    425
    I had this once an old S6 that i had turned out to be a seal where the prop shaft goes into the box, additive wise the only one i use is Millers stop leak,
    dale86's Avatar
    Oct 2012
    354
    Thanks I'll give it a whirl cheers.
  1. TDI Quattro Gearbox oil Change
    By BlackQuat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2010, 13:12
  2. A4 3.0 Quattro Cabrio Oil leak
    By mja4cab in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th February 2010, 17:33
  3. Leaking gearbox oil 2.5TDI with a manual 6 speed gearbox.
    By Joni_s in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th June 2007, 16:44
  4. gearbox oil leak
    By imported_Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2006, 10:52
  5. A4 Diesel Quattro gearbox oil
    By QuattroChap in forum Diesel forum
    Last Post: 8th June 2004, 21:17
