EM TuningChris Nott
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By carpetbagger
Thread: Possible engine mount issue
    Stu-pid's Avatar
    May 2013
    80
    After noticing an annoying creaking on the front end and changing all the arms, today I've done the arb bushes and noticed the n/s eingine mount looking abit deflated from the top with red stuff weeping out of the bottom of it. Could this be the creaking issue
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,160
    Possibly, this will be the hydro mount - I believe they stiffen up at higher speeds, the red stuff will be the fluid leaking, so best to replace it anyway.
    I have just replaced one of mine funnily enough.
    May be worth replacing the front snub mount too - they are only a few quid.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Stu-pid's Avatar
    May 2013
    80
    Yeah I could see the snub one cracking slightly. Where did you get your engine mount from?
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,354
    I've got B5 RS4 mounts for mine, bought from the dealer (cheaper elseware but for some stupid reason I was rushing), far as I know they don't have the liquid so are solid all the time and will not need replacing, also stiffer so may mean the car shakes more and they don't have the plug for the ECU so will throw up a code in vag-com, but yeah supposed to be decent haven't fitted yet though.
    Stu-pid's Avatar
    May 2013
    80
    So you don't need a mount with a connection on then. I'll just get some febi mounts then seen as that's what my arms and arb bushes are.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    634
    Has it boight any codes on?
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Stu-pid's Avatar
    May 2013
    80
    I've only got a code reader not vag-com I will plug it in later. I've not got a eml on
    Stu-pid's Avatar
    May 2013
    80
    No codes but my reader only reads dtc's
    Nov 2013
    49
    Hi had same engine mount fault on my a6 but when scanned it come up with engine mount solenoid cant remember code
    mount was best part of £200 then labour but when fitted felt smoother
    Stu-pid's Avatar
    May 2013
    80
    I'm going to change it I've got a shake on tick over that's getting worse plus it's leaking red fluid out of it. Going to change the front snub bush too as that's showing signs of deterioration.
    Nov 2013
    49
    if its bad on idle you wont be disappointed on end result
    Stu-pid likes this.
  1. possible engine mount on its way out
    By mk2-dee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th June 2012, 00:07
  2. Possible for an engine mount to affect performance?
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th March 2012, 19:19
  3. Possible engine mount problem? Help please
    By moorheadbrian in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2010, 17:27
  4. possibly need new engine mounts.
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2007, 15:42
  5. Knackered engine mount?!
    By davidrees in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2003, 20:50
