Results 1 to 13 of 13
    palfy86's Avatar
    Aug 2010
    Nottinghamshire
    237
    Is running staggered 19" wheels a "no no" on a quattro?
    So im in the hunt for some new wheels and found a wheel supplier with a staggered option but ive read somewhere that its not advisable on the quattro system is this correct, and if it is correct is it possible to run 19x9.5 all round?
    Oct 2012
    426
    A big no no in my book, just the same as towing always on the flat or on the back of the truck
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,570
    Quote Originally Posted by Ian2012 View Post
    Agree with the towing, but there are a few people out there running staggered wheels on A8/S8 Quattros.....they don't seem to have an issue??
    Dan
    2002 2.5 V6 Quattro
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I would try and get the rolling radius to within 3% if I were you, anymore is too risky in my book.
    S4_dan's Avatar
    Jan 2006
    1,570
    With Staggered, I'm meaning the width of the wheels not different alloy/tyre sizes, (i.e 18's front and 19's rear or 40's on front and 45's on rear)
    Is it ok to run with 8.5J on the front and 9.5J on the rear with the same rolling radius all round? My old man has just put a set of 20's on his S8 with this configuration as he did a bit of research and found a lot of other Audi owners have done this?
    Dan
    2002 2.5 V6 Quattro
    Jul 2007
    London
    3,214
    I run 8.5" wide on the front and 9" wide on the rear on my a6 quattro, no ill effect so far. They are 20" s8 alloys but the tyres look a bit stretched on the rear especially on the inside ! Had a blow out doing 140Mph on my private track, was a brown trouser moment getting the car to stop, tyre was only 600-800 miles if that !
    FOR SALE:
    palfy86's Avatar
    Aug 2010
    Nottinghamshire
    237
    Yeah all i was really looking at doing was 19x8.5 on the front and 19x9.5 on the rears.
    Mar 2008
    Dorset
    13,856
    Differing wheel widths and offsets won't affect quattro as long as you keep the rolling radius the same ish..
    palfy86's Avatar
    Aug 2010
    Nottinghamshire
    237
    James the rolling radius, as in the tyre sizes are the same? so lets say 235/35/19 all round.
    Mar 2008
    Dorset
    13,856
    It's all a bit
    If you fit a 235 tyre on a 8.5J rim it will sit differently to a 235 on a 9.5J rim yes? The 9.5 will stretch the tyre more, in theory making the profile lower, and thus reducing the rolling radius. I would suspect that the difference would be so minimal that it would not matter, but it's a theoretical difference if nothing else.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,509
    so far i've been fine on 9.5 rear and 8.5 front on the same size tyres. Like James said, there will be some difference due to tyre wall height, what affect that will have long term I do not know
    Wheelmanwayne's Avatar
    Jun 2011
    Birmingham, United Kingdom, United Kingdom
    64
    Add Wheelmanwayne on Facebook
    265/30-19 rear will run within tolerances of a 235/35-19 and is ideal fitment for staggered fit on a4 earlier a6 models, 275/30-19 sits the exact same height as a 235/35-19 but clearance issues will occur on the rear
    Jul 2007
    London
    3,214
    i will stay within 1/2" if possible and keep same size tyres. Use spacers if you need to fill the arches better. Here's mine on 20" wheels, rears are 9" wide, fronts 8.5 with 10mm spacers all round to clear struts and arches. Had 15mm spacers on the back but the tyres were rubbing on the wheel arch...
    FOR SALE:
  1. Advice needed: Steel Wheels and Winter Tyres for my B5 Avant Quattro
    By mixmaster in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st March 2012, 21:02
  2. Running Low offset (ET) wheels on a lowered S3
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2012, 12:57
  3. Smallest wheel size on A3 3.2 S-line quattro?
    By SuperPuper2000 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2010, 13:23
  4. Running staggered wheels on an s3
    By Sohrob in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2009, 17:25
  5. It's that time of year again - insurance quotes?
    By ColinM in forum General Chat
    Last Post: 14th April 2003, 17:03
