AH FabricationsSky Insurance
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By quattrojames
Thread: Glove box light for not working
    DWH
    Oct 2013
    Bury St Edmunds
    45
    Hi.
    I've got a 2003 Cabriolet.
    Glove box light hasn't worked since I bought the car a couple of month's ago and today looked into why.
    Bulb tests ok , no volts at socket. I've tried with side lights on, headlights on and ignition on and still no joy.
    Car recently serviced and I was told that no error messages where present.
    Any ideas ?
    David
    PS how do I add an avatar ?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,569
    Check connector behind glovebox and also the fuses
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Assuming the cab is like the others, the switch is built into the damper, and that can all be a bit iffy.
    SmoothAssault's Avatar
    Will design for mods
    Dec 2007
    Cambridgeshire
    788
    Could be that if your glovebox hinge hasn't previously been snapped, then someone may have taken the damper off to service it and put the damper arm back in the wrong way around?
    As the door opens, channels in the damper arm squeeze together two contacts, turning on the light. But these channels are only on one side of the arm. If there's volts at the male plug that connects to the damper, then it's likely your issue is with the switch.
    Here's a small write-up on servicing the damper that shows all the parts:
    Preventing the common Audi A4/S4 Glovebox hinge break | Matt Easom
    FOR SALE: Eibach Sportline Springs from B5 A4. £50 - PM for details.
    Mar 2008
    Dorset
    13,856
    Here's a picture of the switch/damper Matt mentioned.
    DWH
    Oct 2013
    Bury St Edmunds
    45
    Amongst the invoices with the car is one from an Audi dealership replacing the glovebox "lid" and so having checked the fuse I think the next place to check is the damper.
    Is it easy to remove ? Is there a guide how to remove or is it self explanatory ?
    Thanks chaps
    David
    Mar 2008
    Dorset
    13,856
    Use your key pop the end off the dashboard, and the damper is accessible in there. Once you've unplugged the sliding part from the lid hinge, the damper will twist out of it's capture in the glovebox body.
    You might need to remove the glovebox to get the damper out, I can't remember. But if you do, I think there are two bolts you access at the top by dropping the lid, and there are three bolts from underneath. It's quite straight forward, don't forget to unplug the light power lead.
    Here's the damper in action:
    SmoothAssault likes this.
    DWH
    Oct 2013
    Bury St Edmunds
    45
    Thanks, I've got the damper out, it wasn't connected to the lid and so the switch was not activating......working the damper manually the light works so that means the electrics are all good.
    The problem seems to be that there's vacuum in the damper which prevents the damper arm from extending.......should there be a valve or air hole in the body of the damper to release the vacuum ?
    cheers
    David
    Mar 2008
    Dorset
    13,856
    Yes, I can't remember where though. Logic would tell me there is a hole at the end of the damper barrel?
    DWH
    Oct 2013
    Bury St Edmunds
    45
    Thanks everybody, all back together and light working correctly.
    Not sure whether there should be an air vent in barrel as I've made a very small one using a safely pin and there's not much of a dampening effect.....not sure how much resistance there should have been as damper was previously disconnected. I had to make up the small pin that connects the damper arm to the lid using a M3 bolt and nut.
    At least the hinges shouldn't break with such little resistance.
    David
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,569
    Good going.............need to lubricate my damper thinking about it as it has started to not smoothly open.
    Mike
    - BUILD THREAD >>
    Dec 2007
    Cambridgeshire
    788
    I don't think it needs any holes putting in it. The soft-open movement seems to need the vacuum in the damper for it to work. Should only require a bit of lubrication.
    Sep 2013
    Portsmouth
    245
    The soft close action is what snaps the hinges.
    I took the piston apart and removed the rubber seal so the light still works but the glovebox just opens without the slow acting option.
    Willenium's Avatar
    Nov 2013
    Herts
    38
    I never knew mine had a light until my bro got his A4 and I was fiddling with the glovebox that we discovered was broken a few minutes after handing over the cash . Classic hinge snapped at the damper side. I took apart the damper and sliced a few rings off the rubber plunger to reduce it's diameter slightly and thus reduce how much it grabs. Obviously that was no use to him in there so I went back to mine and a piece of the damper arm had been snapped off leaving the door to flop open freely. Attempts to bodge it back on were unsuccessful so I transferred the working modified one over and now have a nicely lit and soft opening glovebox.
  1. Glove box light retro fit and puddle light information
    By pns2007 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 17th April 2014, 11:13
  2. Glove box light not working
    By Alan H in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2010, 22:02
  3. HELP! Glove Box Light wiring problem
    By lee161075 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th November 2009, 18:01
  4. Lights are not working!
    By rydinator in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2009, 10:29
  5. boot and glove box lights
    By tj1978 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2008, 10:19
Tags for this Thread
