Volks AutosMonster Motorsport
Results 1 to 19 of 19
Like Tree4Likes
  • 1 Post By Mike.M
  • 1 Post By pauldazzle
  • 1 Post By JimmyH
  • 1 Post By desertstorm
Thread: anybody here gutted their cat (1.9 diesel)
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    As above. Not sure weather to cut flap, empty,and weld back up?
    Poke,hammer,chissel and batter till empty?
    Any other ideas.
    Im not going down the custom pipe route,at the min!
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,333
    Allot of people will disagree and there will be an input on the turbo not having enough back pressure to function correctly without one but personally think it should be fine and will work out cheaper than buying the whole new system you were thinking of getting
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    I agree with you.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,564
    If it works fine at the moment I would buy a bolt on straight through pipe which are about £60 and keep the cat for any future issues.
    45bvtc likes this.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,564
    Mike
    - BUILD THREAD >>
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Thats the one i bought (have) and is not right part?
    Mine goes from turbo to under my seat,much much longer than THAT part. Cannot find any info on this.
    So knock outs my best option.
    pauldazzle's Avatar
    Cardiff
    634
    Had the guts taken out of mine a few months ago by Charlie at Prospeed in Cardiff. He said he's done it on dozens of VAG TDI's & never known there to be an issue with back pressure killing turbos. Made a big difference to my car as the CAT was really blocked up with cr*p.
    45bvtc likes this.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Nov 2013
    Heath Hayes
    951
    I have removed the guts on the cat on previous Passat with no issues. It seems that some cars were fitted with a cat and a downpipe and others came with a combined part.
    It may be that your car has the conbined part in which case you just need to buy a downpipe to go with the Decat.
    AUDI A4 B6 00-06 1.9 TDi CAT EXHAUST DOWN PIPE DIESEL | eBay
    Klarius Exhaust Link Pipe for Audi A4 | eBay
    Karl.
    JimmyH's Avatar
    Oct 2013
    Marham
    242
    Quote Originally Posted by DieselJake View Post
    Turbos do not require back pressure to work, the less back pressure the quicker the turbo will spool.
    deano1978 likes this.
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,333
    Well duh, fifty seconds of google explains turbo's spool better with less restrictions. Argument is that the cat helps restrict the 1.9tdi's tiny turbo, without it the ECU has trouble controlling overspool and will not be able to control surges. Surges can bend rods and snap the shaft when you step on it at low revs due to the boost spikes. This information has been regurgitated countless times across these boards and others with it's fair share of disaster stories.
    Oct 2012
    429
    What about emissions when it's mot time? don't they test the cat function?
    Sep 2013
    Portsmouth
    244
    Quote Originally Posted by Ian2012 View Post
    Not on a diesel
    May 2013
    redditch b98
    356
    Add bradh on Facebook
    Iv got a 2nd hand car that's had the innards removed iv just not had the energy to fit it plan to over crimbo though
    Jan 2009
    150
    Of course removing the restrictive cat (particulate filter on a Diesel) will give you better acceleration. The turbo will spool faster, the problem with the Pd engines is that the turbo is a variable vain turbo, that is regulated by vacuum pressure rather than a conventional turbo that would have its boost pressure regulated by the waist gate controlled by manifold pressure. The ECU adjusts our turbo's by vacuum, so allowing it to spool up very quickly by removing the cat, the ECU reacts slowly so surges occur. The shaft is weak and can break.
    I asked a local tuner to remap my car and mentioned that I was thinking of fitting a decat, they said they would refuse to map it with it fitted as they would not be held responsible for any damage.
    Nov 2013
    Heath Hayes
    951
    I removed the cat on my Passat, I know a lot of other people who have done it as well and they have not had any issues. A tuner who knows what he is doing could alter the N75 map and fuelling / boost to cope with a situation such as a missing cat.
    The ECU will alter some of the PID parameters so that it is better able to control the boost.
    On a standard car I really dont think this would be an issue, A car with an aggressive map may be more of a problem.
    I have seen several cars with faulty N75 valves or sticking VNT's and when logged they have been making 3 bar of boost before they go into limp mode. These kind of issues are more likely to cause damage to the turbo than a decat and a decent map.
    pauldazzle likes this.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,149
    Just to add my 2cents worth;
    Back pressure shouldnt be an issue with a turbo car - the free'er flowing the better.
    I have a 2.5TDi with the precat and both normal cats removed when I had a custom exhaust fabricated.
    If I remember correctly there were three silencers on the exhaust too.
    The difference was notable straight away - the car came "on boost" much quicker.
    You wont boost any more as the map is still specified to give a certain amount of boost unless re-mapped.
    As for limp mode, bending rods.etc - I wouldnt worry, the ECU has very tight tolerances (unless re-mapped) if anything is thrown out of line anywhere it will cut back.
    I wouldnt worry about breaking turbos, as for bending rods - I very much doubt the turbo would produce enough boost to even bend them, especially on a diesel - not sure how much boost the turbo produces on a 1.9 but im guessing around 17-19psi?
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Jul 2007
    London
    3,234
    Jake is on the money there Alex, however the phenomenon is a little more complex than that ! When a turbo shaft breaks- due to over speeding, the seals get damaged and allow oil to pass on the exhaust- very smoky, or in the intake- which will lead to engine runaway and bent rods. The 1.9Tdi has a very quick spooling turbo which, by removing restriction and poor control of the N75 will allow the shaft to break at it's weakest point. Just remember it's simple physics- cold side is compressing air and it's slowing down and the hot side is still driven by the exhaust flow. The harmonic differences (aka surge) is what places huge strain on the compressor shaft and sometimes the compressor blades do deform as well. Spool down surge is not as bad but the best option when tuning is to fit a larger turbo. The extra mass on the turbine will be better for building boost gradually but won't feel as snappy as the gt17 at producing boost, unless you go for a later gen. GTB1756vk which has a better hot side and bigger compressor so you can have best of both worlds.
    In pd130 case with a remap is better to leave the cat in place to smooth surges out IF you keep the gt1749Va turbo, if you go larger then by all means, get rid of it !
    FOR SALE:
    pauldazzle's Avatar
    Cardiff
    634
    My PD130 is mapped & decatted, & I've had no issues or surging at all. 193k miles on the clock, & running like a dream.
    Oct 2013
    180
    I bought in to the idea of having a straight through pipe fitted of a tiny bit larger diameter and then back to the standard diameter under the car with removing the centre box of the exhaust and I'm really happy with the results. The reason I prefer the straight pipe over decat because air flow should potentially be smoother by not having higher volume space for a few inches before being squeezed back in to a narrower pipe.
    My car doesn't suffer any surging either, to my relief.
  1. Anybody here got a Purple B5 in Glespin, South Lanarkishire?
    By dieselfitter251 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th November 2008, 18:22
  2. Anyone here got their CCNA?
    By Caesium in forum General Chat
    Last Post: 21st February 2008, 23:37
  3. Changing steering wheel, anybody here done it?
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st October 2006, 15:25
  4. Anyone on here changed their own Shocks?
    By Tallpaul in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2006, 19:44
  5. gutting a cat
    By dummi in forum Tuning
    Last Post: 24th December 2004, 14:49
