Monster MotorsportEM Tuning
Results 1 to 10 of 10
Thread: Temp gauge....
    Nov 2013
    Harwich, Essex
    22
    Temp gauge....
    Hi my temp gauge has stopped working in my B6 a4, any ideas any body??
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,617
    Scan with VCDS or check wiring at the CTS. There is a way of getting the dash dials to do a self-test. But I can't remember the process.
    Dan
    Here you go It's done via vagcom
    Dan
    2002 2.5 V6 Quattro
    Nov 2013
    Harwich, Essex
    22
    Was working fine then today zip, doesn't move at all not even a blip when you start her up...... Also any one got a rear number plate light assembly as mine dropped out on the way to work this morning
    pauldazzle's Avatar
    Cardiff
    639
    Coolant temp sensor has probably failed. Very common problem.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Temp sender has had it or check the wires on the plug,
    pauldazzle's Avatar
    Cardiff
    639
    You really need to have a look in VCDS/VAGCOM engine measuring blocks to see if the ECU is getting a correct signal from the CTS.
    Even if your stat was stuck fully open I would still expect the temp to get high enough to register on the gauge.
    Does your heater get hot?
    Nov 2013
    Harwich, Essex
    22
    Yeh heater works ok trouble is got no hook up to vagcom
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    Change the temp sensor as you say you have heating as it is very easy to do but make sure you have a bottle of G13 coolant to top up after......very common problem, but usually it sticks to the 70c marking and never reaches 90c.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Nov 2013
    Harwich, Essex
    22
    Showing my lack of knowledge on these cars..... Is there a guid on here or any one got a pic of where it's situated?
    Oct 2009
    Hull
    1,442
    do a search there is shed loads of info on this and guides with pics
    it will also help if we know what engine?
    location in your profile is good to so if there is anyone close by with VCDS they can plug in for you
  1. temp gauge not working
    By nickstevens in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2005, 01:52
  2. Temp gauge
    By imported_Gytha in forum Detailing
    Last Post: 17th July 2005, 19:48
  3. A6 2.5TDI V6 temp gauge falling and rising??
    By imported_Auditurbo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th June 2005, 00:44
  4. Help with my Temp Gauge
    By XXX_18T in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2004, 09:53
  5. A3 temp gauge
    By adjturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 19:45
