JMB RetrofitsBadger5
Results 1 to 10 of 10
    Nov 2013
    10
    i want to run 19s but
    Hi there looking into getting some 19" rs6 wheela for my quattro b6 estate but not sure on what the perfect fitment would be without rubbing or anything thanks
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Loads of info on here!
    A good fit is 9 half rear @ 32et
    8 half front @ 35et
    Thats near enough plum all round for me. If not slammed u could go wider or bigger!
    A little strech...
    Front 235/35/19
    Rear 245/35/19
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Nov 2013
    10
    Quote Originally Posted by deano1978 View Post
    8 half front @ 35et
    A little strech...
    Front 235/35/19
    Rear 245/35/19
    see ive been told not to stagger the wheels or have different tyre sizes as it will nack the quattro system i aint got a clue as its my first audi wat are the rs6 stock offset and a b6 estate on an 03 offset
    Searching for 6th gear
    Aug 2008
    South West.
    37
    I'm running 19" r36 reps, with 235/35/19 and a offset of35. Standard sport suspension apart from b5 perches up front, it sits just right in my opinion. No scrubbage at all. We drove down through France in the summer fully loaded up with bikes on the back for a family holiday and the rears had only just touched the inner arch liner, but only just.
    Feb 2013
    crowle, north lincs
    85
    Where did you get your b5 perches from as I'm after some
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,567
    They will be new from a dealer or VW TPS.........otherwise from a breakers
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Nov 2013
    Heath Hayes
    951
    Quote Originally Posted by abbottk1 View Post
    Thats good advice, Quattro cars with a Torsen centre diff as your car has should run the same size tyres front and back.
    You could have different wheel and tyres front and back but the circumference needs to be the same or as close as possible.
    In the manual it says something like " the tyres all need to be the same size, pattern and make on all 4 wheels" .
    This is because some makes of tyre even though they are badged a certain size will be slightly larger or smaller.
    You are best sticking to one wheel and tyre size.
    Karl.
    Nov 2013
    10
    Quote Originally Posted by desertstorm View Post
    Karl.
    Sound cheers so what fitment and et wud i be best running et35?
    Aug 2008
    South West.
    37
    Steve,-I got them through TPS. part number- 8do412103b. £21.59, hope this helps.
    Feb 2013
    crowle, north lincs
    85
    Quote Originally Posted by JayMc View Post
    cheers ill look into it
  1. Who is running 19s and lowered?
    By FazS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2011, 18:04
  2. Replies: 16
    Last Post: 20th February 2011, 18:34
  3. i want to upgrade my headlamps but will these fit??
    By aldo8 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2005, 07:53
  4. Carlsberg Dont Dont Run Audi Dealers, But If They.
    By StevieBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2004, 08:20
  5. Want to chip new S3 but need help....
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2004, 13:13
