Chris NottMonster Motorsport
Results 1 to 11 of 11
    Oct 2013
    16
    1.8 T single hesitation/clunk
    Hello,
    i'm new to the 1.8t engine, my car has a little problem.
    Its a a4 1.8t quattro avant with 6 speed manual gearbox, enginecode BFB
    When i drive at low rpm there are no problems.
    When i, lets say drive in 4th gear with 3000rpm and then shift back to 3th gear 3500rpm and than give some throttle, i can feel a single clunk/hesitation before the car takes of, when i rev the engine to lets say 4000rpm and then go back on the throttle there is almost no hesitation, its only there after a downshift.
    what i changed:
    -spak plugs
    -engine mount
    -snub mount
    -air filter
    -pcv pipe under the manifold
    -pcv check valve under the manifold
    - Checked diff mount
    - Checked gearbox mount
    it seems the problem is only present with the engine warm not there when cold. there are no fault codes, idle is also stable
    Could this be a bad coil ?
    any clues?
    vivalacoulter's Avatar
    May 2013
    S. Wales
    194
    Follow vivalacoulter On Twitter Add vivalacoulter on Facebook Visit vivalacoulter's Instagram Channel
    If the coils were going then the engine management light would flash to signal a misfire I believe. Do you know when they were last changed?
    Oct 2013
    16
    They are the original and have never been changed.
    May 2013
    S. Wales
    194
    Then it could possibly be worth replacing them, but if there's no code coming up I'd be inclined to leave them for now.
    Oct 2013
    16
    There is indeed no code. The car takes of when i push the pedal, and after about half a second i get a single clunk/hesitation. So i think that rules out the drivetrain mounts...
    Oct 2012
    429
    if it is coil packs then it's worth trying audi cos there is /was a recall for them, had ours done for free, have you scanned the car codes?
    Oct 2013
    16
    Yes no codes, i will try new coil packs this week and report back
    Mav190sline's Avatar
    Jul 2011
    Surrey/Hants
    83
    Call Audi. Had coil packs replaced on my 04 a4 2 years ago and 01 s3 3 months ago. Both f.o.c
    Jul 2011
    Surrey/Hants
    83
    Recall no 28e9 if I remember correctly
    Oct 2013
    16
    changed coils yesterday and the problem is still there, i'm really thinking this clunk when i go on the throttle could be caused by the dual mass flyhweel...
    Oct 2013
    16
    any clues ?
  1. 1.8 T single hesitation/clunk
    By audi5inline in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th November 2013, 09:44
  2. Tdi 130 hesitation problem
    By Burtney in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th March 2008, 02:03
  3. 1.8t engine hesitation
    By CraigM in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2004, 14:17
  4. Hesitating S8
    By rterry in forum A8/S8 forum
    Last Post: 19th November 2003, 13:40
  5. S3 Hesitation (& DV)
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2003, 21:45
