EM TuningVolks Autos
Results 1 to 10 of 10
    Mar 2013
    90
    Knocking noise and engine management light
    Just driving back from the gym and noticed it was starting to judder with a knocking noise then got a little worse then the engine management started to flash, I've managed to get it home and lift the bonnet, the engine seems fine but I noticed the cat (atlest I think it's the cat ) glowing red, I say red it was really dim but the knocking seemed to be coming from that area.
    anyone have any ideas?
    It's a 1.8 turbo 190
    Mar 2013
    90
    It's the pipe before the cat, just to the left of the engine that had a dim glow to it
    Dec 2006
    barnsley
    1,013
    cat could have collapsed and be blocked and stopping exhaust gases escaping ... heating up the affected area
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Mar 2013
    90
    Quote Originally Posted by dualmono21 View Post
    Thanks for the reply .
    the part that was a dim red colour was the part of the exhaust where the lambda sensor is. I'm guessing it's what you're saying it is to be honest.
    Mar 2013
    90
    Just searched the catalytic converter and it seems that's its the part that's glowing red :s
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,570
    Does the engine rev freely? This is common on Vectra C's but without the knocking noise. The cat carbons up thus restricting the flow and the engine won't rev past 3k rpm in MOST cases.
    Remove the lambda sensor from the cat area but leave it plugged in to the electrical connector and start the engine and see if the knocking noise stops/revs past 3k rpm (if it struggles).
    Dan
    2002 2.5 V6 Quattro
    Mar 2013
    90
    Quote Originally Posted by S4_dan View Post
    Dan
    On tick over you can just about hear the juddering, reving around the 3k mark it sounds raspy and juddering pretty bad then reving past the 5k the juddering and raspy noise seems to clear. The engine management light is not permanently on now.
    thats with the lambda sensor in, I had a little little go at getting the lambda sensor out but it's proper tight and I was freezing my nuts off lol.
    thanks for your help
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,509
    probably a coil pack gone causing it to run on 3. The excess unburnt fuel will be the cause of the glowing cat
    Mar 2013
    90
    Quote Originally Posted by Broken Byzan View Post
    Interesting im im hoping we can get the AA round here tomorrow, failing that I've got a diagnostic machine at work with should pin point the fault
    thanks for the info
    Mar 2013
    90
    Ok after plugging the car into a launch machine it's flagged up the coil pack.
    after taking a look at the coil pack in question it wasn't fully pushed down and had a bit of oil on it, after cleaning it up and pushed back down correctly the car is now running fine . Just want to say thanks for all the info .
    Tomorrow I'll be going back to the Audi specialist where the car had a full service and mot and rear brakes done which cost over £500, and some questions are going to be flagged up . Let's just say something's didn't add up.
  1. 8l s3 traction control and engine management lights constantly on
    By rob fulham4eva in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2012, 08:34
  2. EPC and engine management light
    By itsmeagain in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th February 2012, 13:42
  3. Shuddering on acceleration and engine management light.
    By Sant. in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2010, 22:36
  4. Eggy smell and engine management light
    By baz1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2009, 17:40
  5. Replies: 1
    Last Post: 17th August 2007, 23:10
