AH FabricationsJMB Retrofits
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By krisavant
Thread: Wind noise Driver's Door?
    Sep 2011
    50
    Hey guys,
    OK got wind noise from the driver's door. Seems to be coming from wing mirror direction. I say that is where it seems to be coming from - it may not be.
    Have had the car over a year and it was there when I bought it but as the window regulator was broken I just assumed that the window wasn't fully closed due to this and that it would sort itself out when I got the regulator replaced. Long story short; got the regulator replaced and it's still there. I took out tape and taped up all around the window, the wing mirror and where the door meets the car (meaning I had to enter and exit via passenger side) but still have the noise. I did this to rule out worn seals.rubbers.
    All I'm looking for is ideas or pointers on things to check. The noise starts around 55mph and peaks about 60mph.
    What do you think?
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    606
    May be check the actual window,try n put some sort of wedges around it,to perform a better seal,mgt be coming through windows?
    Or mayb tape up outside n c where that gets you.
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    432
    Visit krisavant's Instagram Channel
    I had this after changing window reg. Really annoying, stripped door, checked everything, all ok.
    Bought some heko deflectors, noise now gone
    Sep 2011
    50
    Quote Originally Posted by krisavant View Post
    Very interesting so would suggest that your problem was actually your window not closing tightly against the seal if a deflector sorted it. I will try and tape that area again tomorrow to see if it helps.
    Sep 2011
    50
    Quote Originally Posted by deano1978 View Post
    I taped the whole outside of the door/window mate.
    Sep 2011
    50
    What I have now come to realise is that there is wind noise on the passenger side too which I am pretty sure matches that on the driver's but it can be hard to tell as sometimes it sounds as if it's coming from the rear. Really need someone else in the car to diagnose that issue.
    I will update thread as I work through this if even for others reading who may have similar probs.
    Sep 2011
    50
    Kris that's a nice kit n your car. What is it?
    Looking something like this for my saloon.
    Jul 2012
    432
    The noise I had seemed to be from the top corner of door/window where the rubber met the b pillar, fitting the heko deflectors seemed to have tightened the gap.
    It's the factory gmbh kit on my car with A5 alloys.
    Sep 2011
    50
    Nice kit mate.
    Sep 2011
    50
    Right I kind of isolated this wind noise to the left and right wing mirror areas. Just need to find out now what causes wind noise in those locations!
  1. Wind noise on rear passenger door
    By chrisinns17 in forum New A3/S3 (8V Chassis)
    Last Post: 25th February 2014, 12:45
  2. Wind problem... driver door / window plus door closed sensor
    By @udi A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2013, 23:10
  3. S3 Wind noise - Drivers side
    By Smiffi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2012, 09:35
  4. Wind Noise
    By imported_mav in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th May 2005, 21:01
  5. strange noise when you open the drivers side door
    By MateloT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2004, 13:30
