Badger5JMB Retrofits
Results 1 to 31 of 31
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    Stanley, North East, UK
    292
    Eibach sportline advice wanted
    I fitted coilovers to my car and ****ing hate them. Stiff and clunky. Sick to death of hearin rattles that nobody knows what its caused by. So after buyin normal lowering springs to stick back on instead of them. Are they stiff? Is it like driving a boat? Do the make strange clunks and rattle appear for no reason? Cheers...... (dont wamt it slammed i like a finger between my tyre and arch)
    blacksmoke remap, 18" alloys, coilovers, heko wind deflectors, c/coded door blades, DIS, Cruise, votex front grille
    TO DO: fit my votex front valance (in the shed), c/code the rest of the lowers, sport interior
    Jul 2010
    217
    Out of interest what coilies did you use?
    I used eibach springs on my MK3 golf years ago and they were pretty good but gave an uneven lowering on that, I evenetually bought a spax spring and shock set for it. My MK4 golf had eibach pro street coilies on which were fantastic.
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    I honestly dont know. Cheap nasty ones off ebay 200quid for the kit. I knew they wouldn't be up to much but they were ok at first but now the rattles are doin my tits in and want them off!
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I was very pleased when I ran them on mine, they're never going to be as stiff as coilovers, but then unless you buy decent coilovers it's always going to be a compromise as you know. I'd recommend them if you're doing the spring route.
    Mine will be for sale soon, for a 2.5 q Avant if they're any use to you.
    Nov 2013
    Heath Hayes
    951
    You really need to be spending £500 upwards to get a decent set of coilies. As you have discovered you get what you pay for.
    I rate Eibach springs but I don't like cars that are dragging there rears on the floor. Downside is you get a fixed drop, with coil overs you can adjust it to exactly what you want.
    When fitting springs you need to make sure that they are designed for your car. They fit according to axle weight so there may be say 10 different spring kits for an A4 depending on whether it has a 1.6 or 2.8V6, There are differences between manuals and autos and saloons and estates. If the kit is not specifically designed for the axle weights on your car although it will fit the drops may not be correct and you may end up with more of a drop at one end than the other.
    Karl
    BRILLO's Avatar
    Sep 2011
    Juniper Green, Edinburgh, United Kingdom, United Kingdom
    137
    I'd recommend them as well. Got them on 2.5 avant and had no complaints about them. That was 3 yrs ago so at least they last.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,576
    Always had Eibachs on previous cars and will do on this car eventually or possibly H&R
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    BRILLO's Avatar
    Sep 2011
    137
    Sometimes I regret not fitting b5 perches though. Just to level it out nicely. Lol.
    amar06fbr's Avatar
    Vorsprung Durch Technik
    Apr 2010
    West Yorkshire
    1,033
    sportline 50front/40rear fitted to a 1.9tdi
    For Sale
    climate control (double din non chrome)
    Black roof lining (sportback)
    pm me for more info..
    BBM: 28E07323
    My Panoramic RetroFit
    YSN
    YSN's Avatar
    Sep 2013
    93
    ^^ how many mm are those springs? and is that 18" wheels and what tyres if you dont mind me asking. Im in the same boat as well looking for a set of good springs. But from my own experience from other cars Ive used Eibach and have to say they are brilliant especially with the progressive spring design. Im just a bit concerned about my A4 TDI because right now it has reverse rake i'd like to lower it in a way that the front is lower or both rear and front is the same as right now the front sits a little higher.
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    That pic is a bit low on the front for me, rear is bang on i would like the front that height aswel. Are sportlines that height out the box? (just i currently glide over those little speed bumps that cover 1 lane when both wheels go either side lol) i dont want to catch as i did when i first fit my coilovers and had it that low
    Mar 2008
    Dorset
    13,856
    This is my SE on 30mm Sportline's, it could have been lower, but was perfect for me on rural roads. (the front is sitting a bit uneasy due to the angle of the ground at AITP)
    Jan 2011
    612
    I am toying with the idea of changing springs and shocks on my car next year and was looking for Bilstein shocks and eibach springs, do not want it scraping the ground, would be happy with standard spec, can anyone recommend a good place for advice/buying….
    03MY 52 reg 1.9 TDi 130PS Quattro Sport Avant - 170bhp remap, RNS-E+OEM bluetooth, B7 wiper arms/blades, 4300K HID+nightbreakers/LED sidelights, rear tints, new lights all round, new front/rear screens, frt armrest, s-line kit, cruise/DIS, B7 gearknob/aluminium trims, parking sensors, black grilles, RS4 RARB, S4 front end, black 18" RS6 alloys
    Still waiting..... S4 rear bumper, exhaust tips, coilovers, leather recaro's.... phew...
    sammi's Avatar
    verwood, Dorset
    346
    Follow sammi On Twitter
    we had eibach springs on the b7 special edition made a world of difference, so much so that it made me want them on the b6 s4.. only i and to have H & R springs. Im happy with them. made the car handle much better and it looks so much better too !
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    Hi all
    I have an A4 1.9tdi Quattro salon
    and have fitted eibach springs pro and sportlines
    now what I have found out is the pro kit will lower your car
    if a sport but 15/20 mm but if se then the box says
    30/35 mm
    sportlines will go lower 40/45 on an se model
    only 1 thing with the pro kit the front end will sit higher
    giving you an uneven look .
    so I have pro kit on rear and sportsline on front
    hope that helps you all .
    oh and a nice chapy called Damin can help you all .
    Quattro Jam B12 suspension kit ,Custom Droplinks F/B , HID 6000, 18" RS4 Alloys, summer AMG's .
    RS6 for Show's .Cat gone for walkees, sports six padded clutch DMF
    Remapped 173BHP///278lbft, RS4 F/R ARB's , happy with that ........
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,344
    To be honest I read allot of people saying about the front being higher than the rear but it looks fine on mine (eibach pro kit), what made you choose a different suspension setup for the front and rear rather than b5 perches
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    I think the front looks higher but it sits level with the floor. WIth b5 perces the gap between the arch and tyre is matched but the nose is down. Just what ive noticed from pics after trawlin through the forum
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    Hi
    you are both spot on about the nose been ing down a little , but the gap on the wheels are the same
    both rear and front ... All about the look LoL
    oh I had changed the shocks too
    blistin B12 set up so the B5 perches would not fit over the new thicker shocks
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    il get some update pics soon for you lads, its sittin 50mm front 40mm on back, reson why my mate went for that drop is so it doesnt scrape when the car is loaded with passengers lol,
    For Sale
    BBM: 28E07323
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Look forward to these pics
    YSN
    YSN's Avatar
    Sep 2013
    93
    Look forward to seeing the pics amar06fbr
    Anyone know if the coilovers I listed below are worth a shot? they all have warranty with them but anyone know what the warranties cover?
    Was thinking maybe this might be a good option as the spring option seems like I might still end up with reverse rake.
    JOM Coilovers
    COILOVER SUSPENSION KIT JOM NEW FOR AUDI A4 8E QUATTRO 00 07 | eBay
    FK AK
    Audi A4 B6 B7 (00-08) FK AK Street Coilover Suspension Kit All Models ex Quattro | eBay
    Unknown Brand
    COILOVER AUDI A4 2.0TDI B6 B7 8E SALOON/ESATE ADJUSTABLE SUSPENSION | eBay
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    204
    Does anyone know if they think my car is lowered or standard? I've always thought it sat a bit low and looks same height as the grey one above which is down 30mm...
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    looks like a standard sport set up to me
    BRILLO's Avatar
    Sep 2011
    137
    I think qj's car is an SE not a sport though(the grey one) but I may be wrong. Apologies James if I am. Lol.
    Feb 2013
    crowle, north lincs
    85
    I think that has been lowered as my sport sits higher than that
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by BRILLO View Post
    Mine was an SE, but the Eibachs dropped it 30mm, so theoretically 10mm lower than a standard Sport.
  28. #27
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    204
    I just think it looks a bit too low for factory "sport" suspension. My dads A3 S-Line Black Edition is on stilts compared to mine!
  29. #28
    BRILLO's Avatar
    Sep 2011
    137
    As I thought James. I have the same set up and it is a tad lower looking than a std sport.
  30. #29
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,344
    I'd say it's sport/s-line suspension, only 10mm in it and couldn't picture a previous owner changing it for a small drop.
  31. #30
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    204
    Guess I'll find out when I take the wheels off at some point.
  32. #31
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    For Sale
    BBM: 28E07323
  1. A8 - First time buy, advice wanted!!
    By Shonky in forum A8/S8 forum
    Last Post: 13th March 2007, 22:23
  2. Eibach Sportline Springs and Bilstein Dampers........
    By madkebab in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2006, 18:50
  3. a4 eibach sportline springs
    By curtis11 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th November 2005, 21:19
  4. a4 eibach sportline springs
    By curtis11 in forum Handling
    Last Post: 13th November 2005, 18:33
  5. Springs, things and lowering kits: Advice wanted please!
    By sausagefingers in forum Handling
    Last Post: 4th February 2005, 20:35
