AH FabricationsSky Insurance
    JasonS's Avatar
    Feb 2012
    North Herts
    86
    Cabriolet headlight / bumper adjustment
    I removed my offside headlamp today and polished it up.
    it was easy to remove, 2 bolts on top, slacken one at rear and I was careful not to break the tab on the electrical connector.
    However, after replacing the headlight, there appears to be a bigger gap between the light and the bumper.
    I've had it out and tried re-seating but to no avail.
    I've checked that the plastic tray it sits on is locating correctly in the headlight tabs so it's not sitting on top of them.
    There's doesn't seem to be any obvious way to adjust the bumper to shift it up a touch.
    I've checked the workshop CD and it shows the joint dimensions but no detail on how to adjust the bumper to meet the joint dimension spec..
    Anyone managed this before?
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Jan 2011
    661
    I removed both mine to change the bulbs and had to wiggle the tray a bit and the light unit to get everything settled right.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    JasonS's Avatar
    Feb 2012
    North Herts
    86
    I figured it out in the end.. it's been bashed on the front at some point, so the bumper isn't properly aligned..
    I took off the fog light grille and found that the plastic cowling is cracked, which suggests it's had some impact at some point.
    Now I know why, I don't mind if the gap is a couple of mm wider than it should be.. I only notice it if I look closely.
    I also discovered when looking inside with the grille off that the intercooler is covered in oily dust, so I have to figure out how to clean that out.. My first though was to whack it with my pressure washer, but I don't want to break the fins off with too much pressure, so I'm having a think.
    Previous Audis:
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
  1. Cabriolet rear bumper trim and wheel offsets!
    By markyzs180 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th April 2009, 23:15
  2. Headlight beam adjustment for european driving
    By crazylegscrane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2009, 00:13
  3. headlight bumper question
    By quattroa6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th January 2008, 08:23
  4. Headlight height adjustment
    By Gaunty in forum Volkswagen and other VAG
    Last Post: 22nd December 2003, 16:53
