AH FabricationsJMB Retrofits
    Oct 2012
    426
    Mr Muscle Turbo clean quick question
    I am having trouble getting the egr pipe off, can i use a length of hose small diameter and poke it down the tube as far as it will go or does it have to go deeper?
    ta
    Ian
    mikeygulley's Avatar
    Aug 2013
    Paignton, Devon
    30
    Add mikeygulley on Facebook Add mikeygulley on Google+
    I wouldn't risk it for a chocolate biscuit mate. You need to see the tube goes in the right direction as shown in the guide.
    Oct 2009
    Hull
    1,437
    its easier if you take the exhaust off the turbo and go in from the back
    remove the exhaust from the turbo and take the gaskets off trace around the gasket on to some card and cut it out bigger then the gasket poke the three holes in then put it over the bolts on the turbo so it seals it
    put the gaskets back on followed by some large nuts followed by the OE nuts to hold it all on poke a hole through the card insert some sort of pipe and go past the vanes and fill it up
    Nov 2013
    Heath Hayes
    931
    How about take the turbo off strip it and put it back on. Mr Muscle might get it working for a bit but it's only a temporary measure.
    Oct 2012
    426
    i haven't the time at the moment, and doing a pipe down the egr pipe has i hope worked
  1. WOW !!!!! MR MUSCLE TURBO CLEANNING
    By marktdisport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2014, 18:12
  2. Mr Muscle Turbo Cleaning
    By Oddie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th April 2013, 17:02
  3. DIY: Mr Muscle Turbo Clean
    By alpesh26 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th June 2012, 19:07
  4. Mr muscle TDi turbo clean - PD130
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2011, 19:51
  5. MAf cleaning..quick question
    By Black_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2009, 23:23
